[RIP] Samsung Galaxy Note7 Thread: Share ur last thoughts
tkl23786
Sent from Planet Pluto using GAGT
sho pretteh...
moi likeh...
:D:D:o:o:o
WhiteAnt
You should determine whether you yourself see any use for the S Pen. I personally found the S Pen useful. I don't use it often, but when I do need to use it, it's godsend.
buttttt me never use a samsung note before :( my biggest phone is 5" without stylus huan :( so cannot determine if it is indeed useful. i know what you mean, because sometimes i needed a fine tip end stylus to select a paragraph. that's why i went to ask a fair number of people, 80% say super under utilize or some even mentioned only use on the very first few days and never after that :s22:
IDA approve SM-N930FD which is the dual sim variant which is what we will get. LOL, the single sim variant is SM-N930F and yes we are getting the 64GB version (no need 128GB as its a hybrid microSD/sim slot)
:eek: note 7 really will have dual sim here?!?! can't wait for the full specs to be out :o
omg like that i'm really torn between this or s7e :crazy: just now already thinking to hoot s7e end of year since got dualsim but this one also have lol
tkl23786
ipporek
Sian... was looking so forward to the launch then now realize that I'd have to wait till Oct to get it cos the plan available for upgrade now is the lowest end plan, while the other high end plan only available for upgrade in Oct... can only wait and see while everyone gets their Note 7s...
siandiao
Moderator
Moderator
if they really make it waterproof, then I'll be back at Samsung :o
tkl23786
can never be waterproof. it will be water resistant.
Because of the S pen (or rather, the S pen Slot), it is difficult to be waterproof. At most is water resistant.
It will be an engineering feat to waterproof the Note with such a big S pen slot which is usually connected to the motherboard...
Edit: wa.... siandiao is now deluxe moderator ****...
kmkimlo
Poisoned.. Ah.. Might come back Android.. After Beng shops lower the price.. :)
