[RIP] Samsung Galaxy Note7 Thread: Share ur last thoughts
kmkimlo
To be honest, I think the Iris Scanner is just a fad, a hardware bloat, just like the Heart rate sensor......
It will be something to try once or twice.. Then turn off to save battery.. :s13:
seller4
Sent from Planet Pluto using GAGT
nomoreliaola
Removable battery and IR blaster is gone for good and will never return for now.
Yes we are getting dual sim variant, IDA only approve SM-N930FD.
5.7" Quad HD AMOLED dual edge with 3500mAh battery
Omg my current note 4 need to buy new,bartery cos existing one does not hold,charge... Will same thing happen for internal batt?
Sent from Samsung SM-N910G using GAGT
WhiteAnt
agree :o but heard contact lens users or specky iris cannot be detected so it is indeed going to be a fad, but we're paying for all these features :o
Lavitz_4044
seems really stupig to jump to note 7 by skipping note 6, whats their agenda anyway by skipping a digit? to match S7? so match already can do what fancy stuff?
WhiteAnt
because more and more koreans are becoming christians, so they skip number 6 :o :crazy:
they want to align their number with galaxy s series. now s7 and s7edge, so if sell note 6 people will think old model from last year.... i personally think the real reason is because of upcoming number in iphone 7
kaputzzz
its to streamline their flagship series... they want to associate s7 and note7 as their high end line of phones.
so when they release future editions ppl will recognise the pattern, s7 > note7 > s8 > note8 etc.
shager
This is the first I've heard Christians think 6 is unlucky or whatever. It's actually 666 that is the mark of the beast. Christians are also not really superstitious as it goes against the faith of putting your trust in God alone.
It's more to align the Galaxy and Note to the same naming convention.
guards80
They are fully customizable and can limit the screen's brightness, change its resolution (e.g. drop it to HD to ease the stress on the chipset), limit the chipset and stop background data.
Fellowes
hopefully we will get the exynos version
Yes, we are getting the Exynos version!
Inside the Note7 is Samsung's latest Exynos 8890 processor paired with 4GB RAM. This octa-core processor is the same one found inside the S7 and S7 Edge.
siandiao
Moderator
Moderator
the leaked retail box got put water resistant.
https://twitter.com/stagueve/status/760348678620086272
basically it is the s7 edge in a 5.7-inch form factor with S Pen and iris scanner!
nowadays, becoz too many pple spoil market, never cover ports properly, then demand 1 to 1 exchange when their phone spoil, hence even though rating is there, but they put water resistant with many disclaimers, just in case :crazy:
siandiao
Moderator
Moderator
Because of the S pen (or rather, the S pen Slot), it is difficult to be waterproof. At most is water resistant.
It will be an engineering feat to waterproof the Note with such a big S pen slot which is usually connected to the motherboard...
Edit: wa.... siandiao is now deluxe moderator ****...
aigoo im moderator since 2010. y u no notice me :( :(
