[RIP] Samsung Galaxy Note7 Thread: Share ur last thoughts
garychengjw
Banner up at WestGate.
Sent from LGE NEXUS 5X using GAGT
seller4
This is the first I've heard Christians think 6 is unlucky or whatever. It's actually 666 that is the mark of the beast. Christians are also not really superstitious as it goes against the faith of putting your trust in God alone.
It's more to align the Galaxy and Note to the same naming convention.
Agree. Dun think it got to do with Christians.
Ppl always think the Note series is one generation behind due to today naming convention (Example S6, S6 edge and Note5).
Skipping Note6 and called it Note7 will eliminate this confusion. Now everything is generation 7. (Example: S7, S7 edge and Note7)
Sent from Planet Pluto using GAGT
seller4
agree :o but heard contact lens users or specky iris cannot be detected so it is indeed going to be a fad, but we're paying for all these features :o
I heard the initial setup of the iris scanner, you cannot wear glasses or contact lens. But once it is setup, the iris scanner will work with glasses or contact lens.
I will try out tonight and confirm.
Tsoukalos
ah boss can try out e distance also... if ppl w deeper eyesight like me, testing time bring close close, then specs normal distance e phone can catch?
PeasantBeing
Yes, we are getting the Exynos version!
Inside the Note7 is Samsung's latest Exynos 8890 processor paired with 4GB RAM. This octa-core processor is the same one found inside the S7 and S7 Edge, but with a faster quad-core 2.6GHz and quad-core 1.6GHz processor pairing.
why exynos? better than snapdragon? exynos compatible with games like pokemon go or not?
kelvinti
So, confirmed that the Note 7 is a Dual SIM 4G LTE Standby with 4G+3G for Singapore set? :s11::s8:
