Hi, I got Sony X850D, manage to get Toggle (Media Corp App) APK file version 3.0.9xx to installed but it display vertically on the TV. Anyone get this works in Sony TV? I know LG is officially supporting Toggle, anyone got the APK file from LG?
Thanks for the information. I will try it out on my TV later. I tested on my phone, able to set the orientation, but on TV which step I should do first? launch this application first or launch the Toggle first? You set the orientation to which one? I saw quite a number of option.
Orientation follow by Toggle.
Set it to "Automatic (full)" and click Ok. You only need to do it once. It will remember the settings even if you restart the OS.
For LG, user do not need the APK file as it is officially in the LG store. Just click with the magic remote to install and then open it to watch. It is so simple to use.
Thanks for the information. I manage to set the orientation but now Toggle cannot start. Previously I installed the version 3.1.1, yesterday when I start Toggle it prompted me got newer. I download the apk file for 3.1.2 (which suppose already the latest version). After install still the same. I restarted the TV (on/off turn off power and on again). Still the same so I uninstall 3.1.2, reinstall again, same problem. You encounter similar problem before?
Yah, I tried installing the 3.1.2 but it kept saying there's a new version and redirect me to Google Play Store which is also having 3.1.2.
I deleted the app since I already have Toggle installed on my Apple TV.
Hi, understand, I am just hoping some one root the system and extract the file and he/she can share with others who is not using LG TV.
It is not recommended to do that as it may void warranty. Some Tv not that cheap.
The cheapest way is to get android Tv box.Understand, but there are still some expert out there doing itso I am trying my luck to see if any of them seeing this post.
Toggle downloaded from Google Play into Android TV box cannot play video. You can install but when come to play the video, nothing happens.
yea toggle has yet to fix the issue of not being able to play in android tv box. already feedback to them many months ago...
You may be using the old app so can not play.
Where to get the new apps file?
