1.5k pC
Artermiz
for monitor wait till comex @ suntec better deal for monitor @ comex/sim lim sq/lazada/qoo10
ZrE0_Cha0s
MSI h110i AC pro (itx)+i3 6100-$295
CORSAIR VENGEANCE LPX 2400MHZ CL14 ( 4GBx2pcs )-$85
WESTERN.D 1TB BLUE 64MB SATA3-$77
WINDOWS 10 HOME PREM 32/64BIT-$159
SAPPHIRE RX 460 4GB NITRO-$225
FRACTAL DESIGN CORE 500 ITX CASE-$99
Is this good?
CPU+MB : well still preferable u get a i5 6500 for better performance.
RAM : maybe get a single 8GB valueram
Storage : with your budget u should include a SSD as a boot drive like Zotac MLC 480GB @PCTheme.
CPU: u can consider getting GTX 1060 or RX 480 (but im aint sure which resolutions monitor u getting and do u need a high refresh rates?)
Case and PSU : u dun have a psu included, but i need to know if u really want to get that FD Core 500 or not. for the psu will be get this Sliverstone SFX 500W Gold, as i think should be quite fitting for the case psu limitations.
GreenBandit
Monitor all I need is 23inch and good Colours and 1080p
Case idk lah it seemed ok so I put in the list. Can help me create a better list? Pls
nashii
Intel i5 6500 + MSI h110i AC pro (itx)
Silverstone SFX-L 500W
Kingston Value RAM 1x8GB 2133Mhz
Silverstone Sugo 13
Samsung 850 Evo 256Gb
WD 1TB Blue 7200rrpm
Zotac Amp 1060
ZrE0_Cha0s
MSI h110i AC pro (itx)+i5 6500 @416
G.Skill 2400Mhz 8GB @50
WESTERN.D 1TB BLUE 64MB SATA3 @$74
ZOTAC MLC 480GB SSD@189
ZOTAC Mini GTX 1060 @399
WINDOWS 10 HOME PREM 32/64BIT @$159
SLIVERSTONE ML07 @$118
SLIVERSTONE SFX 450W GOLD @135
Total: 1540
All prices are quote from PCThemes.
Sorry for the slight overprice, if not i try looking for other case, or if u are alright to get your win 10 OS from reddit?
GreenBandit
Hmm. No I can't get online purchases :( Will the price be lesser if it's ATX? Also no monitor or kb?
Total: 1540
Krabs.
:eek: ? locally sell zotac 1060 mini for 399 ? amazon usa sell usd $200 = singapore dollars 276
Encrypted11
Are you sure you are looking at the correct model? The nomenclature abit inconsistent. 1060 3GB isn't a fully enabled chipset like 1060 with the 6GB variant. It's almost more like a 1050 Ti.
Isn't the mini 6gb going for $369 from TD though?
extemporisation
MSI H110i Pro AC's DDR4 tops out at 2133Mhz. Think TS can just get 2133Mhz
Total: 1540
ZrE0_Cha0s
Well this the ATX build with lowest value.
MSI B150M BAZOOKA PLUS + i5 6500 @433
CURICAL 2133Mhz 8GB @47
ZOTAC TLC 120GB SSD@59
ZOTAC Mini GTX 1060 6GB @399
TECHWARE ALPHA ATX CASE @69
FSP HEXA+ 500W @68
Total: 1308
Prices taken from same shop. blue words are the changes i made.
hope it satisfy ur needs.:o
