Huawei P9 - Change the way you see the world. #OO
dawndy89
Is it normal for P9 to take more than 2 hours to charge full battery. I charged from 8% and it's more than 2 hours already still haven't full battery. Using the original charger
Bryson
Thank you @michaeltan for the advice. :)
I've also noticed that the piece of glass covering the camera scratches easily. Any idea how to replace them in time to come? I believe there are others whose facing the same problem too.
Bryson
can sic where you buy? :s12:
i cant find the tempered glass but matte screen protector.
I suggest using film screen protector. Got my set from ebay, branded as terrapin which comes in a set of 6. Glass protector will make the corner of the display less sensitive..
Bryson
Have you tried using another charger to test?
MichaelTan
Just use the transparent hard case which came with it. Never scratched for mine.
xtramadness
You can try using a nano coating of liquid SP to increase its resistance =:p
Zon
the free casing in the box cracks easily... like it though.
as for P9 charging, the default charger in box does not support fast charge.
only P9 + charger is fast charge.
you can get a P9+ or a Mate 8 charger as mentioned in reviews.. go google.
but my understanding is, fast charging is for rapid charge in a short time frame. in full charge, it takes the same time as normal charger.
Today i went to service my P9plus due to crack screen. I broke this morning and make my way to Plaza Singapura for replacement. Their service is superb and I only have to wait for 30-40mins and the phone is as good as new. Thumb up! :)
yah that day i went for my lunch come back my phone fix liao. the staff also very friendly.
lioncity
just bought my Huawei P9 Plus... haven't really start using it yet but I do hope it is performing well for me. :D
