Oppo R9s/R9s Plus
amazingone
16MP rear and front camera on the R9s and R9s Plus ~
Notice the new antenna design too
Sent from Sumire using GAGT
amazingone
Micro-thread antenna line design, a new antenna art ~
R9s leaked in full glory, in Rose Gold and Silver option
walkofwinners
such a sexy beast being led down by their lacklustre operating system.
used the r9 plus and it was a gorgeous device.
however, notifications pushing were a constant hit and run.
sanjaynblr
Using R9 Plus for last few days. It heats up every few minutes and also causes constant battery drain. Will monitor for few more days and see how this goes.
amazingone
Solid state fingerprint sensor on the R9s series, similar to the OnePlus 3
amazingone
OPPO has redesigned the antenna bands on the R9s, such that the previous wide antenna bands of around 1.5mm~2mm width on the R9 has been restyled to a series of three micro thread bands, each width of not more than 0.3mm!
This helps to reduce up to 60% of the dimension that the previous antenna bands took, and also helps to increase the metal ratio on the back to be up to 98.8%, creating a more uniformed metal back body.
With the change of the antenna bands design, OPPO has also redesigned the internal structure of the antenna layout in the phone.
The 4G network optimization and WiFi enhancer will greatly improve the networking experience on the R9s!
OPPO has also seize the time to do some redesigning around the phone, including improving the glass curvature at the front, polishing the edges and improving the metal back to be more ergonomic.
