Huawei P9 - Change the way you see the world. #OO
jlekssp
did you receive the Huawei HiCare EZ-Link Card? Is it suppose to be in the box?
this phone is great....I just bought as well :)
just bought my Huawei P9 Plus... haven't really start using it yet but I do hope it is performing well for me. :D
qyc_91
Anyone received any update for the 64GB version of P9?
Mine is still stuck at the original firmware :/
iichigoz
Hi guys, anyone can tell me what's their build number for the P9? Can be seen from "About Phone" in "Settings." I'm wanting to revert back to stock rom. Thanks!
xtramadness
I bought from Qoo10 already and applied too. Doesn't seem to help much other than making it less prone to dust sticking to it.. :s22:
Did u get the original real one?
:s12::s12: mine seems to repel liquid/fingerprint a little better. Dust not sure thou
tazzi80
Opening Google Chrome seems to dim down the screen. Is there a settings where I can not make it do that?
anubiskhan
Hi all,
Need your advise if anyone is using Huawei P9 Plus. It's an awesome phone with Leica lens and the picture quality is simply superb with many other amazing functions. I only have one issue with this phone and it's the notification. It is not showing except for my sms, gmail, fb & whatsapp. Rest of my app notification, like Carousell, shopee, Grab, Uber and many other apps are not showing at all in the notification.
Anywas to fix this? I tried some steps after calling the Huawei helpdesk but wasn't so helpful. This is the steps that I followed as guided by helpdesk:
Settings --> Notification panels & status bar --> Notification center.
I have to select every individual app to appear in notification but still it doesn't appear. Anyone got solution for this. Your assistance is greatly appreciated. Thanks in advance. Cheers.
ttylei
Huawei P9 Screen Protector
Hi,
I got a screen protector for the P9 at a random Simlim shop and there are lots of scratches after just 2 days.
Anyone know where to get a good quality screen protector in Singapore for the P9?
Thanks.
anubiskhan
Hi,
Thanks.
Hi ttylei,
I bought mine from Carousell at $12 ($9 + $3 delivery). So far so good.
Look for seller: koopman. Very fast delivery and well packed.
moisuperman
Urgent help! My apps went missing after I switch it on. It went to a safe boot first, which I do not know why. After which I did a restart again, my apps are still missing.
*Found it. all the apps are on the other pages. Dunno why also
StealthNinja
Hi,
Thanks.
try benks quality not bad .
jlekssp
I am also hoping to hear some advice. Seems like LinkedIn, LINE or Wechat, they don't notify consistently....i have to open the app then suddenly I see some msg dated a few days back. If I don't open it, it will never notify...anyone got any advice to get this working? Luckily what's app is fine, but this is strange.
Hi all,
Bryson
Go to phone manager, click onto the battery logo then go to protected apps. Select those apps you want to have it running in the background to receive notifications.
sh6268
You can try go to setting, advance setting , battery manager, protected apps. And on those apps that u need notification.
Hope it works..
Sent from HUAWEI VIE-L29 using GAGT
