Recommend a Good and Cheap Air-Con Service Company
benoit_nly
Anyone hooted those from Qoo before?
Seems many good reviews.
Also how to decide whether need to do gas top up?
Is it by frequency, top-up every year for eg?
hahah bro dont bother trying man. waste your time and money only. i kena conned once from groupon and that is it. no more online cheap deals. knn no service no problem. service alr dunno wad valve spoil.
if are paying $10-20 for service, dont expect too much really. u will most likely pay for other things that may just pop up from nowhere.
i was referred to a decent company (newway.sg) by my aunt and fellow hwz bros. pretty solid reviews can go check it out yourself if interested.
endlssorrow
for those who is using ah yi, does it come with warranty? he does not have a company or what right? just a normal good uncle who do servicing.
if got problem, tell him to come back, he will come back anot easily?
maur_james
I don't think he has a company, but if anything wrong after servicing can call him back.
He's not that old, maybe 30/40ish...
enzysg
Can anyone PM me a recommended aircon service guy - Mr Ng or Yi or uncle/ aunty (contact details) they like that is decently priced? Thanks!
bertye88
I intend to service my hus air-cons, but dunno which company is reliable and provides good service, anyone here can help to recommend?? What's the cost roughly for servicing? Pls provide the contact no. and name of the company. :)
Hi, you may want to contact 97862060 for aircon servicing
christie78
HI,
Need some advice here..
Have a 5-6 years old Mitsubishi Inverter system 2 unit..
For 1 of the unit on everynight, having some problem..
Back in April, serviced once.. then Aug service again as not cold.. was told no gas.. fully top up....then in Oct.. aircon no cold again.. was told that might be due to gas leak.. and advise to do a pressure (N2 test).
Can recommend any good service company with good price?
Have checked a few.. cost of Pressure test about $240 - $480...
Issit worth doing the test??
Or should i just service & top up the gas like every 2-3 mths?
TIA ")
empirestrike
HI,
TIA ")
no need presure test 90% piping problem... top up gas if cost around 50-100 buck depend on yr type of gas. if u hv big budget replace the whole set settle once and for all.........
souleclipse
hello !
There could be a problem with the compressor. I think the contacts that are recommended in this chat should be quite decent. I have a contact whom is a friend, you could call and check it out if you would like to. His name is Mr Ng at 83660998.
Hope this helps !
J
No offence, but the only thread you post was on this aircon recommding thread. You created account on Aug 2014, and your first post was about recommending (or Self Promote) aircon service by this Mr Ng
14-08-2014
mm you should have asked the person to come back and get it back into shape for you ! since you already paid for it. I used treecoolaircon and thought its not bad, this guy seems to be very nice, not the usual kind of aircon man that looks unfriendly. I like his service, can he will say he can manage. if can't he will tell me he can't do it.. 83660998 try him if you want.. all the best with your aircon!
And a list of all your post putting number here and there about Mr Ng.
http://forums.hardwarezone.com.sg/search.php?searchid=31570259
I understand if someone is good and you try to help them refer more business. But being active in this forum (And In particular this one thread) for the purpose of recommending particular 1 guy for over 2 years don't seem right.
Either you're getting commission, it's your relative/family business or you're MR NG.
if you're either one of them.. the best way is to come clean and then ask your customer who are senior member here to post their review.
I am not here to frame but i don't want see innocent EDMW getting their money ripped off on 'recommended' Service.
endlssorrow
Thanks for highlight such user.
Very important to many users.
Thumb up for u bro!
14-08-2014
gentoro
Haha - chill chill. Stopped trolling la. I also wanna recommend my service guy but I lost his number after I change hp. :s13:
endlssorrow
y didnt try chemical wash ????
HI,
TIA ")
yaksowmi
HI,
TIA ")
It all depends,
how long more will you stay in this house?
Are your aircon piping covered inside the wall or not?
I recommend you to get others aircon companies recommended here to try to check your aircons.
Glorgo
Glorgo on-demand house service
Hi all! Find your air-con service at glorgo.com! Instead of waiting for a quotation, place your first booking directly using our fixed pricing.
Login now and redeem our promotion code 'GLORGOLIFE', you will enjoy $20 off your first booking! (this promotion will end on 31-Dec-2016, so hurry up!)
Thanks for your time!
