the ONEPLUS 3
Skyy
A few qns regarding a3010 set if you dont mind
1) Is the a3010 from 131express rooted since it comes with oxygen OS installed by them? It does mean alot to me cause i wont be able to sync my company mail on the phone due to some restrictions.
2) Is there a way to unroot it and still use oxygen OS?
3) For the a3010 that was flashed with oxygen OS, are we able to get OTA updates or do we have to manually update them eg: nougat update.
1. Actually a good practice is to always factory reset and wipe your phone clean when you first get it. This will clean any malware installed by nefarious shops. 1 step further would be to download oxygen os from oneplus directly and flash it yourself to be 100% sure. I also use it to sync my company email via VPN & it works fine. But it really depends on your company email implementation and whether there is MDM involved.
2. Yes u can. Assuming u don't use an apps checked by Safetynet, meaning u don't use Android Pay or Pogo then sure u can root it
MGeaR356
Just curious, in the website of oneplus 3t, it states China set supports A3003 Band 8.
Isn't that 4g+ for Singtel?
lockks
i saw its selling $445 for the oneplus3t. thought i see wrongly. modern tech pte ltd at qoo10
seems like it couldn't work now.
blackestvoid
seems like 128gb is now available, but not sure if is a3003 or a3010
and they have free warranty that must be paid for
rharish_21
My Oneplus 3T (A3010 Chinal Version) always heats up quite badly whenever i use Flipboard, Carousell or even during long phone calls.. My Previous Oneplus 3 (A3003) model never had this issue..
May i check is mine a isolated case or other A3010 also heats up? Can any kind soul using A3003 Oneplus 3T confirm that their model doesn't heat up?
Thanks
garychengjw
Thanks
My 3T A3003 no such issues. Only when gaming does get slightly heated.
Sent from Google PIXEL using GAGT
ChuaHeAn
Guys not sure if you all have this problem, but my android pay only work when the phone is unlocked. On my v20 it works even when the screen is off.
Skyy
well unlocked is good right, means it's more secure, else people can use it to pay for stuff if you lose your phone and the NFC is on
koreanlover
Anybody tried topping up EZlink/Flashpay card at MRT station GTM using UOB Mighty app?
Mine gave an error.
I am using beta Nougat, Oxygen OS 4.0.
