Kaby lake plus skylake mobo
picopika
Hi I need advise as per title.
Sent from Xiaomi REDMI PRO using GAGT
picopika
Thanks for replying
What are the advantages of kabylake mobos versus skylake mobos?
I'm not intending to do any form of over clocking
Encrypted11
Optane
No Optane
If its a 100 series board, you need a BIOS update with the kabylake processor whitelist. Maybe the shop can help you flash.
wad3v3r
Need bios update :s13:
but heads up ... you need to update with a skylake chip in the mobo first if im not wrong.
royfrosty
But before you do that, why? Why a 100 series motherboard over the 200 series?
picopika
Because of budget issues :(
if skylake boards are able to do the job and the kabylake motherboards don't have any significant edge over it .... More justifiable to get the previous fen ones
harharhar
Isn't it almost the same price?? At most $10 difference.
royfrosty
..... No where near cheap either. Unless you are looking at a h110 board. Else no point. There is no price droped. Lastly lesser benefits. Apart from that h210 boards will be coming in to replace the h110 boards.
darkarn
If this is the case, why not go with Skylake CPUs and mobo? Or since you confirm not going for overclocking, go with non-K CPUs
Or even go 2nd hand market for Haswell stuff; can take advantage of slight price reduction of DDR3 RAM somemore
We need to know your use case and budget to help advise further :o
Encrypted11
So far Intel hasn't had H210 in their ark.intel catalog. Just like 9 series only got Z97 and H97 . Should be no refresh. :s34::s34::s34:
picopika
Which combo are you looking at?
Thank you all for the replies
I'm intending to get an i5 7500 plus mobo combination
Not intending to get a Z board, looking at H or B ones
picopika
Thank you for your reply, I have already bought ddr4 ram from Amazon for a decent price
robbedzombie
see lah guys... u all give idea wad lah z1xx mobo with kaby lake chip. now ppl start to ask these type of questions, seriously its onli a few bucks between them. if u want buy one macdonald meal after hooting m,obo then buy a previosu gen baord
Encrypted11
SLS basement can buy a meal and drink.
darkarn
Ah I see, then I guess your plan of using i5 7500 should be no probs then :o
poooooo
lesser is better :D
170 series overkill with 89898989 types of unnecessary inventory list :s13:
