Recommend a Good and Cheap Air-Con Service Company
hwmook
Anyone using Panasonic aircon?
I am currently using cu-xs9rkz and after switching on via remote control, it usually take some time (30 secs or so) for the unit to blow out cold air.
Just wondering is this normal.
Normal, my house unit have been running like that for years.
Nighthowl
Hi, I'm using a Daikin System 3 Inverter and the FCU keeps tripping my whole house. Any suggestions?:s11:
James_Lim_2
Good provider of aircon servicing
I recently came accross these guys who allow to book my sir con servicing directlu from their website and also can find my receipts on their website for my landlord. Prices are decent.
Aircon servicing
empirestrike
dissapointed that I waited almost 2 weeks for the aircon man to come cos of his tight schedule and then he rejected my servicing cos there was no parking at my place. I offered him another place that is about 50m from my place and free parking and offeres to carry his equipment also but he didnt want cos he left already. sian. waste of time waiting for 2 weeks.
I need an aircon man to take out the coil from the FCU and then clean it in the toilet with chemical wash. 2 FCU.
anyone can recommend?
where u live? no parking space? so jialak.... :(:(
yaksowmi
Hi,
Anyone can recommend any good aircon servicing that cleans the fancoil radiator and chemical clean the fins?
I cant seem to contact Hock. Any other good alternatives?
Thank you
Why do you need to clean fancoil radiator? is there a radiator on the fancoil? i believe you just meant fancoil & the fins.
i use SgOzoneAircon.com for many years. Their price & service quite ok
benoit_nly
Is sys2 general cleaning n maintenance $90 reasonable??
guess so? newway charges me about $130+ for 4 units. works out to be about $30+ per unit. if you have lesser units i tink price per unit may be slightly higher. they are our regulars and we are very satisfied with their service. definitely value for my money.
word of advice. dont bother going for those offering at $20+ per unit. once i go gian those cheapo deals from groupon. $15 per unit. worst $60 spent ever in my life. got my mom so pissed even. :s13:
mr_slackerz
Hi, just want to check with you guys before calling the aircon repairman.
My aircon unit in 1 of my bedroom totally cannot turn on/start.
Remote controller no problem.
Tried to switch it on using the manual switch on the unit itself but still cannot turned on.
Used testpen to check incoming power is present.
My aircon unit is mitsubishi starmex model number MSY-GE10VA-R2.
Installed only last year may.
No problem with the other 2 units in the other bedrooms.
Anybody encountered this problem and maybe can assist to troubleshoot.
Thanks.
grynove
what is the common SOP of cleaning aircon actually? do they normally clean the roller? my unit is toshiba system 3. noticed very dirty on the roller. asked my regular aircon guy. he said toshiba cannot take out roller one. next time shud get mitsubishi. oh well. my unit always dripping water. if anyone can suggest me a good one.
wuga98
i have a quote from the aircon dealer but it is expensive due to their labour cost, as i know what is wrong n what is needed to be change, can some recommend a good aircon tecnician that i can call and tell him what to do as it will be cheaper for me.
terumo
Maybe the PCB is faulty, can get the agent to come and check if its still under warranty.
Thanks.
empirestrike
Thanks.
maybe wiring and pcb...:eek:
empirestrike
toshiba which model? can suggest u REDCON AIR...:s13:
empirestrike
what u want to do?:s11:
