the ONEPLUS 3
KeYoKe
Don't worry, I am very chill, it was a discussion to clarify things, nothing more nothing less, just like you said, "forum is a place to seek help and share your thoughts and ideas".
no worries everything dandy
anything stated here would be informative for anyone who is interested in 3t but anal about certain issues and helps them in their consideration
i don't think anyone would have raised this non-issue if not for me
:s13::s13: the tone both of u talk so serious, thought gonna have fire soon ah :s22:
kashix
haven't leh, in the end I more or less decided to keep it lol
Sent from 1+3T using GAGT
Hahaha, I don't lie one, if really good then I'll say, not good no say, you just google, OnePlus 3T smoothness by changing governor xda. Hehehes : )
Btw bro, you how many phones? Since you intended to sell, whats ur other phone?
babyalann
Well I'm the guy who bought over the op3t from kashix. So far so good it's really fast compared to my s6. Still getting used to the size though.
On a separate note I find that the spigen ultra hybrid is a tad too thick and heavy for my liking. Any recommendations for a thinner casing with slightly less protection?
Bro you can take a look at nillkin frosted shield! Less protection overall but still solid. For me I'm using rugged armor from Spigen !
Sent from OnePlus ONEPLUS A3010 using GAGT
hsm1user
Same here, using Spigen rugged armor but I have a 2nd case that I bought from qoo10, a simple transparent tpu which is very thin. It's the 1st result when you search OnePlus 3T case on qoo10 I think
babyalann
Just gotten my rugged armor from Spigen. Solid case not fatty. Abit too tight for the stock screen protector which causes some bubbles *OCD kills*
shonen45
Hi,
Where do you get Spigen rugged armor for OnePlus 3T? Shipped from the USA, or from Qoo10 / Lazada? Or at a local retail shop? Please share how much does it cost.
There are some clones on Qoo10, without the logo of Spigen at the back cover. So I can't be sure which seller would have genuine stock.
Thanks in advance.
hsm1user
Buy directly from Spigen Singapore website, search on Google. I bought from there too. Cost $19.90 by normal singpost postage
Hi,
Thanks in advance.
shonen45
Thank you so much for the quick reply.
I just placed an order on Lazada. The seller stated is Spigen Singapore Flagship Store. $19.90 with free delivery. I use ShopBack, so there is a little discount in the form of rebate...
Cheers.
jtec14
My lookalike one at a cheaper price :D.
Nice, solid and slim case but may lift up screen protector.
koreanlover
Hi,
Thanks in advance.
Got mine from Mobile Hardware at Burlington Square. $18.
http://www.mobilehardware.sg/collections/oneplus-case
Sent from OnePlus 3T using GAGT
KeYoKe
http://i.imgur.com/nHJhVXw.jpg[IMG][/QUOTE]
hahaha this case is from taobao. i like it. using it for my mate 9 too
[img]https://img.alicdn.com/imgextra/i4/2101546432/TB2LatUfX5N.eBjSZFmXXboSXXa_!!2101546432.jpg_430x430q90.jpg
