MacClipper
- Jan 1, 2000
New BIOS seems reportedly improved but has a few quirks eg. like this oneseems like got new bios: http://forum.hwbot.org/showthread.php?t=167530...
FYI
No worry there, just that unless you have issues with 0902, 1001/038 are just short term fixes for certain bugs till the new AGESA BIOS comes out.GG i update to 1001 liaos
timaa66 said:My rig has been stable for a few days running P0 the exact same settings as Purple haze above with the same ram timings. You guys got me a little worried about voltages in the past 24hrs so I decided to pull out my multi meter and see what is happening in my rig. My voltages are as follows under load with no LLC:
Actual(DMM)
Vcore 1.449
SOC 1.134
RAM 1.324
CPUz/HWmonitor
Vcore 1.461
SOC 1.177
RAM 1.373
BIOS Reading
Vcore 1.504
SOC 1.177
RAM 1.373
BIOS Setting
Vcore offset 1.35 +.08125
SOC 1.125
RAM 1.31
Overall it appears my voltages are running higher than what i set them (.009-.017v) but are actually less than what is being reported. In BIOS it appears that my voltages are actually about .05v lower than what BIOS is saying they are across the board.
A fair summary of Ryzen present state of affairs, very new, lots of tweaking and undergoing gradual maturing... like his essential hwinfo64 utility.
Click
Mumak said:I have just released HWiNFO v5.47-3115 Beta and pulled the earlier builds.
Another note about the new CPU current/power measurement for C6H and PRIME X370 under ASUS EC sensor. It seems that neither this value is accurate, as it covers the Vcore rail of the CPU only (VDDCR_SoC is not measured/included). Moreover due to the nature of implementation (HW/firmware), under frequent Vcore fluctuations the final power value might not be accurate.
I will try to find with ASUS a better way how to measure CPU power using on-board circuits, but don't know if that will be realized..
So don't expect to just throw down the money, grab the hardware, jump in and start overclocking to the max.![]()
2 of mine got bricked. Thinking of switching to Asrock, MSI or GB
The culprit was reportedly setting the Vsoc too high potentially corrupting the EC chip in earlier BIOS versions. A really good example not to push voltages too much in any totally new platform when much is not well known or established.
btw, the 0902 BIOS fix was already posted very much earlier, in fact almost 2 weeks ago...
http://forums.hardwarezone.com.sg/h...st106813312.html?highlight=0902#post106813312
RMA your problem sets meanwhile, just confirmed with Asus SG that they will be assisting in such cases.
2 sets and with BIOS 1001 on stock... think you should consider getting in touch with Asus SG and Avertek to investigate further. I will alert them to your case.I did no overclocking... Both were on stock settings and on version 1001
Try the 0902 bios. Use the USB flashback to flash.I did no overclocking... Both were on stock settings and on version 1001
