ASUS@SG
Suspended
- Jul 26, 2011
the beta firmware is targeted at only Singtel Fibre Users as it involves vlan configuration. The current 9736 beta firmware has a bug on vlan where its currently unstable and the ports used is also a bit awkward at port 1 and 2.
the beta firmware rides on newer firmware version higher than 9736 official version, but also will come with its own set of issues, though the beta firmware has its vlan improved.
its up to you to see if you wanna try, if you don't like it, you can always roll back to 9736 officially released version.
Dear all,
Let me add more information.
The beta firmware requires factory default setting after the update and do not restore any saved config file as Vlan setting have been changed.
Best regards,
JK
