[Maylyn - Networking] ASUS ROG Rapture GT-AC5300
ASUS@SG
Suspended
the beta firmware is targeted at only Singtel Fibre Users as it involves vlan configuration. The current 9736 beta firmware has a bug on vlan where its currently unstable and the ports used is also a bit awkward at port 1 and 2.
the beta firmware rides on newer firmware version higher than 9736 official version, but also will come with its own set of issues, though the beta firmware has its vlan improved.
its up to you to see if you wanna try, if you don't like it, you can always roll back to 9736 officially released version.
Dear all,
Let me add more information.
The beta firmware requires factory default setting after the update and do not restore any saved config file as Vlan setting have been changed.
Best regards,
JK
maylyn
Dear Singtel user,
We have a new beta firmware available for you to test.
Please take note "Beta firmware contain bugs".
Please drop me a pm to register.
Name:
ISP:
Internet Speed:
Best regards,
JK
Dear all,
Best regards,
JK
Add-on ~ 25/03/2017
Important note ~ please reset to factory default first after updating the firmware before setting up again.
There are the usual preset SingTel MIO/SingTel-Others profile to select from or for advanced users can always use the manual settings to setup more than 1 set of the SingTel TV STB.
Please contact ASUS SG to register your interest on the above quoted post.
KoBe_4EvEr
Updated the Firmware and still experiencing issues with the connection. It will keep disconnect itself again and again.
KoBe_4EvEr
assumingly both of you are using the same singtel home fibre (regardless of speed plan), then why one is stable one is not?
i think its worth zooming deeper into the settings.. hahas..
I'm testing it again after resetting. Hopefully no issue.
maylyn
I guess the Singtel-MiO profile will be be useless?
There are still SingTel peeps which uses VOIP via the Aztech router with telephone RJ11 ports together with the ASUS routers rather than via the SingTel ONT.
So SingTel-MIO profile is still useful ;)
ptey
Jut got the GT-AC5300, so which is the firmware to install for Singtel Fibre and MIO TV? Thanks!
renfred89
