BeeFour6922
- Dec 3, 2006
Hello, I'm here to share my experiences about kdk fans in Singapore. I recently took on a side job of repairing kdk fans and have repaired about 50 fan to date so i will share some of my observations. I know kdk is the brand that many people trust when it comes to fans and the brand of choice for many homeowners, but before you spend your hard money you might want to read on.
The biggest and most common problem with kdk fans i notice is failure of the PCB board. This happens on the electronic living, wall and ceiling fans. What often happens is that when you press the button to turn on the fan, the fan automatically switches off. Or when you press the oscillation, timer or 1/f yuragi button the fan will switch off. This problem is observed on kdk and Panasonic living,wall fans manufactured after about 2005. On ceiling fans particularly A11YS, M11SU and R48SP, the fan may become stuck in one speed and will no longer respond to the remote. All this is caused simply by one small capacitor in the PCB board of the fan. I've had numerous customers who have thrown away their cosmetically perfect fans because of this problem when it could have been easily repaired.
Secondly is the dip in quality of their fans. As I've seen fans from various generations of each model, i can see a consistent downward drop when going from one generation to the next. The main thing is the PCB board, my old kdk fan of 20 years has its PCB still perfectly working whereas my recently bought fan of the same type ,PCB failed within 2 years. I notice that PCB failure is most prevalent in M40KS, N40HS , PL30H and M40MS.
Thirdly is the price, although there has been a drop in quality, prices have only been going up and many of their fans with PCB problems are around the $200 plus mark.
Also , if your fan ever fails,in terms of the faulty PCB or the fan suddenly stop running. Please dont throw them away, although kdk might fail, it is also one of the easiest fans to repair. If the PCB, simply get the capacitor changed and your good to go. If the motor suddenly stop spinning , the thermal fuse is blown and can be changed, If spinning slowly is because the motor capacitor is faulty. Bottom line, even if these fans fail, they mostly can be repaired. So do a favor to the environment and your wallet and try repairing before throwing away. Also do consider carefully before buying kdk fans. Finally if anyone needs help repairing or advice on how to repair or what fan to buy feel free to text me at 91246065. I can help with all models except ceiling fans.
models affected by PCB problem:
KDK - A40KS.A40HS,N40HS,N40KS, M40KS,PL30H,S30KH,P30KH,U30NH, N30NH, T30LS, P40MS, M40MS , KC4GR
PANSONIC- F400HS.F400KS,F408HS,F409KS,F409MS, F307KH
Motor problem and not spinning suddenly can happen on all models including those not mentioned above.
I bought 3 units of KDK SC30H box fan in late 2014. The louvre function stop working after 1 yr and it caused the fan to shutdown . Initially I thought it is my luck with a lemon set, but come 2nd year, the 2nd unit experienced the same.
I logged a call with the distributor requesting the technical manager to return my call over these inferior quality product. No calls from them.
Thanks to TS for sharing his experience. He helped me to replaced the capacitor at a fraction of service center's repair cost.
Those who need help to pry open the kdk box fan to replace the capacitor, can PM me.
