Nvidia GT 425M (Error Code 43)
thexone
As titled, I have just installed Windows 7 Pro SP1 (64bit) on my laptop and is having issue with the nvidia graphic adapter..
This laptop (Lenovo Y460) comes with Intel HD Graphic as well as Nvidia GT 425M.
The error code 43 appears on the Nvidia GT 425M when I installed both the graphics drivers.
This is the hardware id for the Nvidia 425M
PCI\VEN_10DE&DEV_0DE0&SUBSYS_396C17AA&REV_A1
PCI\VEN_10DE&DEV_0DE0&CC_030000
Any advice?
ZrE0_Cha0s
yes, have already installed both the drivers, but when i remove the Intel HD graphic driver to troubleshoot, the nvidia adapter will not have error code 43.
this is so weird cos usually laptop own driver should be the most optimize driver to be able to support the hardware. some more its win7 whereas your system is during that period (win8,1 i believe?)
thexone
Yeah, this is the first time i encountered this issue.
The laptop came with Windows 7, apparently there wasn't any issue last year when formatting, but this time round the driver provided didn't work.
So what happened was that when I was trying to install the OEM driver for Nvidia, but it did not allow me as the hardware (GT 425M) was not detected. So i went ahead to download the generic driver from Nvidia website. This driver did something even more weird by installing the driver of GT 440 instead of GT 425M. I thought that was the reason why there is error code 43 so i try to modify the nvidia inf to install the correct driver. Still, it doesn't solve the issue.
ZrE0_Cha0s
which lenovo display driver u downloaded for your laptop?
thexone
NVIDIA Display Driver for Microsoft Windows 7 (64-bit) - IdeaPad Y460, Y560 - 8.17.12.6704
Intel Onboard Graphics Driver for Microsoft Windows 7 (64-bit) - IdeaPad Y460, Y560 - 8.15.10.2104
86technie
Have you install from Intel -> Nvidia.
Usually that is the step but not Nvidia -> Intel.
thexone
Good morning.
Let's try this for a change
Use Display driver uninstalle(DDU) to uninstall all drivers
http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Download drivers from Nvdia's website.
i have tried using this method before but doesn't help.
i have tried using this method before too and tried again but doesn't help.
86technie
Oh... I Google and I fear that the graphic card maybe faulty.
https://www.drivereasy.com/knowledg...this-device-because-it-has-reported-problems/
You can try the method but however if it doesn't.
You can clear reset the BIOS to default if issue remains
than you may have RMA your laptop.
Which usually is replacement of the motherboard.
thexone
