ElZedHaitch
- Mar 6, 2016
ern, maybe u can tell us whats the games u playing? and does other games also have the same issues?
next check if the drivers have been updated?
or maybe can try to tweak some settings and see?
I play all kinds of games. Drivers are all updated. Some cpu intensive games always end up bottlenecking the system. Of course the small indie games are fine. But games like hitman hits the limit very hard and fast. Even starcraft can hit it quite quickly. Oh. And even cs go at high frame rate can hit the limit but of course that's near 120 fps before it even comes close.
The issue is that I like to multi task, open a lot of files and programming stuff which also eats some cpu (not that much though, but it adds up).
I think my windows installation is getting a hit bloated or something though. Becoming a little slow alr. So maybe I will reinstall and reinstall drivers to try.
But anyway I plan to get a new cpu sometime anyway. If I were to pick one now, should I just get a 4790k and oc or a bit so it can last another 2 to 3 years?
