bananasiong
- Feb 21, 2016
always take a backup just in case...
yeah.. gotta format an ext-hdd to hfs+ now
No they don't wipe, but if you request for it, they can do it too.I'm going to Apple store for replacement tomorrow.
For replacing just the display, are they gonna wipe off my SDD?
When replacing the LCD, they will replace the bottom casing too. At least for me.
Anyway the technician will remind you to do your backup.
All the times I did at Alab they left my bottom casing untouched. If they replaced the bottom casing do they laser etch your serial number as well?
wow they replace the bottom casing as well? As in the Apple Store itself? Lucky you. for my case i went to QCD and they replace the display panel only. I ask for the rubber feet replacement which they said have to change the whole bottom case & its gonna cost and $400 plus.
