most valued prepaid card
lohsenglte
4G DATA SERVICE ACTIVATION
Is this for people who wish to use data on the prepaid? Do I need to activate it? I have no data plan, using the original 4G SIM Mcard $15($18 value).
It's already activated for you.
It's for 3G M Card customers that wants to use free data plans on 4G, if they don't have the 4G paid data plans.
For 4G M Card customers (activated since last year iirc), there's no need to activate alr.
Note: Disable 4G on your device for your M Card without data, because data charges may apply even with data off.
Sent from Redmi Note 4 MTK using GAGT
Basking123
If one uses data, how does one control the data usage? I understand from their website, the Mcard top up and data plan top up both contain data, how to control/monitor the data usage without running the risk of subjected to 0.2cent /KB rate?
lohsenglte
Check your usage in M1 Prepaid Portal or though *100*2#.
Really? how so? data is disabled from the #100# selection , they still incurred in a 4G phone?
Oh, but switch off data in *100# will terminate all data transfer and not be chargeable. Note: Free data or paid data, you're not allowed to access the web until you manually enable data.
4G will be put on hold too, therefore you'll only get M1 3G.
CrispyPeddler
hi, any good recommendation for data prepaid? im done switching phone every 2 years.
plan to switch to data prepaid to cut the cost and still enjoy high data bandwith
bockers
Is Starhub prepaid data stackable? Like if I get the 3 day 1GB and the 7 day 10MB then will I get 10 days 1.01GB?
luei74
efreelancer
What dual sim phone are value for money nowadays? I intend to use 1 M1 prepaid and 1 M1 mdata. But how do I know which number then since both M1 lol
