- Aug 9, 2011
Contact hotline 1633 direct to Broadband tech support line, not cs.
Explain u have just swap router due to upgrade plan.
Request the staff to Refresh IP, as ur speed is below.
They can check ur connection at their end.
Follow their procedure which may take several minutes.
If line busy, call later.
Most router do retain previous IP and this may be the cause on having multi IP address, which may also cause speed issue.
As u may be on ur previous plan IP.![]()
I think most of the time, it is isp fault. I also suggest calling them but night time hard to get them and need to wait for support to pick up. May be call during office hours.
