LaksaTitan
- Apr 7, 2013
can SIC some real life photos?
im looking at this watch too
how much you got it btw?
Random HDB watch shop can do bahi guys .... where would you all recommend to change battery for G-Shock?
Model is GA-1000
It's my very 1st G-Shock to run out of battery
Found the battery and the inside of my watch with fingerprints and stains.kena one retardo change my g's batt before, the gasket not seated properly and got pinched
from then on all i self change.
daiso $2 precision screwdrivers enough for the job.
opening screwbacks is another story, very easy to mar up the caseback if you don't have a secure holder.
those aliexpress 2 prong very easy to slip and have hardly any mechanical advantage to pry, need a proper wrench or best, those bench-top screw press opener.
Model is GA-1000
No idea. Can't find the watch strap size, having the impression the switching may fray after a while so wanna change to something else if possible lmaoCan this watch strap change to the yellow brownish strap of the gsts120?
Pai se late reply go home I take for u, hooted for 298 at bencoolen
Dang itQoo10 can get this watch at 230 now after using coupons.
may I ask where to get this?
Unable to find this at Bencoolen last Saturday....
lastly, is there a difference between this and the GX-56BB-1?
GXW model has the multi band 6 feature. World time sync with atomic clock, not useful in SG cos we are too far and too densely built up city.
The GX model is the regular one.
Sent from 富贵山庄 using GAGT
Thank you.
may I ask is there other shops than Bencoolen that carries Japan models?
Heard there is this skywatches in Chinatown peoples park?
