Dash promotion (No referral)
Trazora
Guys, need to do anything in particular to activate Visa Paywave function? I am not able to perform any paywave transaction, and upon checking the Paywave status, it says inactive.
Ensure that your NFC setting is turned ON. Check that your Visa payWave service is ACTIVE by going to Settings / Update Preferences/Dash Visa Account/Status. Launch your Singtel Dash App and ensure your screen is ON when you tap on the payWave terminal. If the previous steps didn’t work, uninstall then reinstall your Singtel Dash App.
koreanlover
Ignore the screenshot it is for another thing. Update to latest version of the app, look under other services, transfer to bank account. No need register
Thanks for the info.
Thought so troublesome have to go down to their office.
chiokcc
Trazora tried transferring to bank account already?
realised got so many banks to choose from now. i cant try cos no balance in the dash account.
I tried and successfully FAST min $1 back to a local bank
ice_angel
It can now transfer $$ to another Dash account now?
Last time only if you have SCB account then can.. I don't have SCB account so was not able to...
Anyone tried?
Trazora
Anyone tried?
Better still can transfer to any bank that support FAST.
gravityz3r0
Exactly, it says check make sure that Visa Paywave is ACTIVE, but it does not mention what if it is shown as INACTIVE, which is my case. I'm under impression that it should automatically be activated, no?
nekoarc
Using Singtel Dash 4.7, the 'Transfer to Bank Account' leads to the same 'register at store' page that the Send Tab 'Find out more' does. What magic did you guys do to skip registration?
Perisher
Deluxe Member
Gonna try the transfer to bank later. Not useful for iphone user without the NFC.
heng_ah
There's no magic.
If you use account (phone number) which was registered with SCB Dash previously, no need to activate / register at store anymore.
efreelancer
Can buy singtel prepaid sim at singtel shop using dash? Got 5% rebates? Intend to do porting from M1 to Singtel.
Trazora
Ah, so it's SCB Dash. Singtel Dash still asks for registration :(
Thanks.
It is Singtel Dash. But guess need to register if previously not registered when using SCB Dash to do the transfer.
Trazora
still goes to same registration thing
Yes. As already clarified above if you use account (phone number) which was registered with SCB Dash previously, no need to activate / register at store anymore. If not then need to register.
chiokcc
Reminder that the "old" DASH will ceased to work after 30 Sept 2017.
Try to get the FAST transfer to work. If not, suggest to transfer to SCB Dash first if you are worried about the $$ being tied up.
