Wireless Charger for Iphone 8 / 8+
cloud77
Just to share i got a 3rd party wireless charger to try for my iphone 8+ , it works ok with a rubber casing.
yongster84
Yeah, quite a number of YouTube videos show that the Samsung wireless charger is able to charge ip8/8+
athenodorus
just not sure if samsung's one is charging at what watt for iphone. higher, lower or same (7.5w) as the recommended morphie's and belkin's.
szeli
do you need to place e phone in an exact position?
Hello_Kitty
can it charge more than 1 devices??? the apple one can charge 3 items at once
Yunamr
Yesterday when I in Nubox (looking for screen protector for iPhone 8 plus) they offer me Mophie charge force power station, based on their unit it also work with casing (I used flip casing).
nsguru
Anyone know a cheaper alternative of Apple wireless charger to charge both phone and watch at the same time?
clokwerk0
Anyone currently using IKEA’s NORDMÄRKE wireless charging pad?
Seems like not a bad price at $79 for a triple pads wireless charger.
Audiology93
I'm using the older Samsung wireless charger for S6 and it's charging at around 4-5W.
chengsun
Tried my 8plus with the 3 demos at Ikea. All 3 will work if my 8plus is naked.
Probably because my case got a ring attached at the back and it cannot lay flat on the charger. My case is those cheap $5 soft TPU case with ring attached at the back bought from simlim. Not sure if without ring will work or not.
renfred89
of cos la, you need close contact with the wireless charger for it to work.
your ring on the casing won't work...
chengsun
boh bian, 1st time using a plus size iphone, feel insecure if I do not use a ring...
