Just to share i got a 3rd party wireless charger to try for my iphone 8+ , it works ok with a rubber casing.
can it charge more than 1 devices??? the apple one can charge 3 items at once
Anyone currently using IKEA’s NORDMÄRKE wireless charging pad?
Seems like not a bad price at $79 for a triple pads wireless charger.
super cool find, friend
But the output 5w only per device I think.
Tried my 8plus with the 3 demos at Ikea. All 3 will work if my 8plus is naked.
Probably because my case got a ring attached at the back and it cannot lay flat on the charger. My case is those cheap $5 soft TPU case with ring attached at the back bought from simlim. Not sure if without ring will work or not.
of cos la, you need close contact with the wireless charger for it to work.
your ring on the casing won't work...
