my mazda3 is 2yr old. anyone driving beyond 5yr? any prob?
Paging kia2700... come in please.Hi, mates.
Should be collecting my ride this month. Interested to know a few things about mods and its pricing.
1. i was quoted $1200 for glossy black finish for mazdaspeed 3 hatchback bodykit. Is $1.2k standard price..?
2. those who have change your rims, could you kindly share your ET, ie offset. I'm looking at an 18 inch with ET 35 rims. Tyre wise, would be 245/40/18. Any advice on ease of availability and rubbing against fenders..?
3. those who install the mazdaspeed bodykit, did you install the fake exhaust tip..? Is it legal and will it void warranty..?
Thank you.
1.2K I dunno, I didn't install, what color is your ride? Not all finishing can go with black glossy.Morning-morning good everyone.
Paging... Paging...
Right now, point 1 is most important. Need to settle deposit.![]()
Hi, mates.
your bk from tek or third party?
if it is a clip on bk then consider quite costly.
best to get tire shop to advise u
cosmetic shouldn’t void any wty
Thank you.
Point 1:
From 3rd party. Not sure can be mentioned in this forum. However, from what I know, its the only workshop which provide mazdaspeed bodykit in our island.
Gnixer, when you mention clip on, are you referring to add on lips..?
If you are, then yes, its a clip on.
You might want to minus off the spray work and compare the cost of the items before committing to it.
Body kit is easily available everywhere. Anyway their Mazdaspeed body kit also not genuine, just mould out from the factory.
Body kit is just a cosmetic if you want me to suggest i would suggest you to invest in your car interior which you get to enjoy more than fixing the scratches and dents later on.
Cars are after all cars which you don’t get to keep for life.
Thanks for the advise, Gnixer. Really appreciate. ��
Based on my Google search, I couldn't find any other workshop doing bodykit for mazda 3 facelift. On top of that, i'm only looking at add-on and not changing the whole bumper. Besides that, I don't fancy bringing in bodykit from overseas as its too troublesome for me.
No need bring in, pay someone to do for you. Anyway whether go jb or order online, outcome is still the same.
CKK please drive kutty car to jb to install and come back with full polish.
Btw u can ask TEK the body kit supplier.
Hi, mates.
Thank you.
1. 1200 glossy n 900 matt is jdm price right.
U can buy online which is much cheaper but u need to find ppl paint n install lo
Better nego for a better price
2.i using 18" rim. 18/40/225, no problem. Got owner go up to 45 also OK, so no worries
The only thing u such worry is that 4.5 finger gap between ur car n tyre... Sian
3. Nv install. Got ppl install n I thought recently the regulation change a bit. Can go outside workshop do svc won't void warranty liao... Though not much link la.
If u r changing to that bodykit u sure need another exhaust ma, or else damn ugly
Auto sensing wiper or non-auto sensing?Hi, currently driving a Madza3 2016 for past 3 months, earlier tonight, the wiper just dun work...i try restarting the engine and also wait awhile, however wiper did not move at all..anyone knows what went wrong?
