Mazda drivers come in here!
EJB
Bros your recommendation for workshop for RIM+tyre change? Two years mark is here.. m3. I use the car just to get around don’t mod or anything... so... good cost-performance is fine for me. Thanks
I won't say tyres are performance mod... I do it more for safety, I don't chiong 120 these days, max 80 sometimes 90 depending on road traffic, still, it's good to have.
I also changed my hoses to SSBH.
Tyre & rim change I did at Li Hong Enterprise @ WCEGA lvl4 (the entrance to the plaza is lvl2 already). I went down 2 weeks before for dekitting and rim selection + ordering the tyres.
Then collect car liao I go down and change. Bart did his at Stamford I think. CKK dunno where he kapok his from.
MR, yours is red right? Go for silver or bronze or gold rims please.
ChaoKeng_Kia
did mine here
https://www.facebook.com/RMTeamRims/
Kia7200
Mine at HH tyre at yishun
chopra
my car suddenly died on the car today. should i worry? battery dying issit? i just went for 30k servicing 2 weeks ago at mazda and they didnt say anything.
background:
i pressed brake as usual and activated istop on at red traffic light. when traffic light turned green, 2 symbols popped out. i didnt go and notice. one is a red symbol, the other is an orange one. car couldnt move. i was already 20min into my ride.
i switched off engine and turned it on again and the car went back normal.
mine is 2yr old mazda 3.
Dixon.
background:
I stop any light?
abbas kutty
Hi, mates.
Wish to check.
When you purchase your mazda, were you given an option to buy the in-house insurance with an NCD Protector and without an NCD Protector..?
Could someone enlighten me on this.
Thanks. ✌
ralliart_ray
Hi, mates.
Wish to check.
Thanks. ✌
got in-house insurance meh? i thought they using AIG
Dixon.
cant remember. should be yes.
My istop and master warning light lately been going cranky.
The master warning light was Amber
Istop light was Amber and blinking.
Had to reset the istop and it went back to normal.
Try the following
On your engine, let it warm up a while.
Once done, switch off.
On the car to the acc mode (without switching on the engine)
Within a few seconds of oning the acc mode
Hold onto the istop button for a few seconds till you heard the beep sound.
Hold on for another 5 seconds after the beep.
Let go then on your car engine.
The istop should be Amber (without blinking, meaning istop is off)
Press the istop off button again to switch on the istop.
It should be blinking green.
Leave the car to idle till the Amber blinking disappear.
Then drive around a while to make sure it all goes back to normal.
Repeat again if it does not work.
Do take note this helped me from goin to the workshop a couple of times.
But still monitoring if it's really my battery going cranky.
Hope this helps anyone else out there.
abbas kutty
My bad.
Yup, it's AIG. I classify it as in-house insurance as you have no option but to buy insurance from that company.
I've yet to check with my SE as to why I have to pay more almost $200 for the NCD Protector.
That's why I enquire in this forum if anyone can shed some light. 🙂
Dixon.
Hey guys battery starting to have problem already.
Anyone changed Mazda 3 2014 battery so far?
Whats the damages like?
Kia7200
My bad.
Can bargain la
Get the insurance agent contact n bargain with them directly better
Dixon.
Ard 2yrs can change Batt. Model Q85, change outside better, ard $180 can get
My batt is 1.5 years old le.
Heard start stop battery more exp than normal battery.
Hopefully my WS don't overcharged me.
The istop keep blinking Amber and master warning light continuously on.
Guessing Should be the battery.
