Xiaomi Mi A1 (Mi 5X) - Mi Dual Camera, Picture Perfect!
lwm999
Anyone uses Quickpic? After Oreo update, when I moved a photo from an internal storage folder to a SD card folder , the photo remained in the internal storage folder. Reinstall the app did not help.
Is there another way to take a screenshot beside pressing the volume down and power buttons at the same time? Find it weird and troublesome to do it.
petrarchan
anyone knows how to connect automatically to wireless@sgx?
whenever the profile is saved using the wireless@sg app it will auto restart.
What are the configurations for manual connection?
tiger2013
You mean the app crashes?
If you can't use the app, you have to connect to Wireless@SGx manually and authenticate using SIM.
Select Wireless@SGx network, when the options page pops up, select SIM. Save and you should be connected to the network.
If no SIM... then the other option is the unsecured Wireless@SG.
ZrE0_Cha0s
still can use manual? though they said all must use app to access lei
rty
Are you guys able to change your Whatsapp notification tone? Since Oreo update, it always goes back to the system default notification tone. No matter how many times I try, the change won't stick. Now if say an SMS comes in, I cannot differentiate from listening to the tone whether it is an email, SMS, Whatsapp or any other thing.
petrarchan
there is no SIM option leh..
only GTC or MSCHAPV2
then type what in identity?
3plexxx
Need to use the wireless@sg app to setup and configure for initial use. Once done, you can uninstall the app. If wireless@sgx is available on location, it will Auto connect. Otherwise, for wireless@sg, you will need to login and an SMS will be sent to you for authentication.
tiger2013
petrarchan
i connected then chose sim.. click connect again and it restarted!
kept restarting once i click on sim and click connect! :(
tiger2013
Your phone restarted or the Settings app?
What about other wireless networks? Can you connect without issues?
tiger2013
phone restarted.. other wireless networks no issues
Strange problem. Never encounter something like this before. Wireless@SGx is using 802.1x EAP for authentication.
Are you on any of SingTel combo plans?
If yes, connect to SingTel WiFi using SIM. See if the same problem occurs. Seems like your phone is having problems with 802.1x EAP.
petrarchan
not using that.. using starhub
redname
Do all those sold in the market currently comes with stock android ROM?
