Oneplus 5T
onlinehero
so far from what i have seen, only nillkin tempered glass will fit the spigen rugged armor. orzly and the official oneplus TG wont fit the spigen rugged armor as the lip of the case is quite thick
hmmm where can i get this nillkin TPSG?
KeYoKe
i see that there is both 0.2mm and 0.3mm one - do you happen to know which is the better fitting one? or from your experience, which is generally better :o
nt very sure liao this one. what i can say from my experience with TG is:
0.2mm less shock absorbtion compared to 0.3mm, easier to crack as it is thinner. However, might fit the curve of the screen better as it is slightly softer then 0.3mm ones, so will have lesser halo effects
other then this, i cant think of anything else
onlinehero
yup, you're right.
https://www.youtube.com/watch?v=MWV2DBHoWU8
shows the H+Pro with spigen, and an earlier video i posted shows the spigen rugged armor lifting up the Orzly one.
Shinji Kagawa
Yea bought last thurs, got on Monday.
Im not sure if its air bubbles, they dont seem to move when i press down. Is it the glue?
Yea can take pic when i get home.
stone1978
Hi guys, may I know how to set notifications alert on WhatsApp and wechat? My set don’t display how many msg unread on these 2 apps unlike my previous iphone. Pls kindly advice. Thanks
sunht
Stock Android doesn't have that feature. You can install Nova launcher and Teslaunread to get what you want.
Sent from OnePlus 5T using GAGT
kashix
If I'm using very bare casing like original oneplus 5T tpu casing, best TG is orzly? :s11:
anyone tried the TG by moshi.moshi or casefactorie for the 5T?
stone1978
I got lava red 128gb for $867 including a xpower travel charger from 131express 2days ago but they now dropped price.😂
Skyy
I got lava red 128gb for $867 including a xpower travel charger from 131express 2days ago but they now dropped price.��
u know the xpower chargers (or any other non-Dash chargers for that matter) won't give u more than 1.5A right?
