Oneplus 5T
silverwing
Check with u guys, can i use my current charging adaptor (samsung) to charge op5t?
Heard that it's not good for the battery if constantly using dash charging, is it true?
tiancaiz
can charge, but normal charging speeds lor won't be dash charge. Actually most batteries now will only last 2 years, so the difference whether you dash charge or not will be negligible afaik.
Sent from OnePlus 5Teh using GAGT
kashix
dash charging ftw!!!!!!!! :s13:
Skyy
depends on if u always dash charge to full and keep it there or you dash charge to 80% and stop.my personal experience and experience of my friends is that if you keep charging to 100% and keep it there (like charging overnight), the batt capacity reduces significantly after 1 year because you keep stressing it by charging to 100%
anyway if u're the type who change phones every year, it's a moot point, but if you're the type that don't change phone till it spoils several years later then you might want to take care of the batt.
kashix
Anyone running 2 Sim on the 5T. Is the battery drain significantly higher for mobile standby and usage? Thanks
deepuvjy90
I am on dual sim, both are Starhub(1 local and 1 overseas sim). Comfortably getting 5-6 hours SOT with moderate usage. There is no significant difference on using 2 sims. Super happy with the battery life.
kashix
Thanks for the feedback nice to know!
Sent from OnePlus 5T Lava Red using GAGT
kashix
Pasted the orzly on the 5T, the sides got like lines like air bubbles that cannot be pushed out, is it normal for those bro whom pasted the orzly? Thx
jinsong
I didn't buy the 3 pin plug and use a traveler adaptor instead. Will it reduces the charging speed?
rECKleSSfElla
Its normal to have air bubbles around the edges which seemingly cant be pushed out. They should disappear after 2-3 days. I find that it more effective to use your fingernails + the cloth they provided to push out any air bubbles instead of using the applicator card as per instructions. I managed to push out all visable air bubbles. For your case, if the bubbles dont disappear after 2-3 days, remove and reapply or use the 2nd piece of tgsp.
Skyy
u should test yourself cos no one has the exact same usage and sim cards as you. my personal experience is it does affect battery like if i have 2 sim cards active at one time, but i feel that's to be expected, since you have 2 radios active now.
Skyy
are you still feeding 240 volts to the charger via your traveller adapter? you are right? so no diff to the charging speed..
stone1978
use a hair dyer blow the bubbles
kashix
I paid mobile shop outside small fee to help apply the glass as I can't paste tg. Hopefully it'll subside on its own. How come will disappear on its own after 2-3 days? Because of heat? Sian :( but thanks for the advice bro! Appreciate it!
rECKleSSfElla
I paid mobile shop outside small fee to help apply the glass as I can't paste tg. Hopefully it'll subside on its own. How come will disappear on its own? Sian :( but thanks for the advice bro! Appreciate it!
I dont know whats the science behind it but if you read the instruction paper, it says any remaining air bubbles should disappear after 2-3 days. And its actually extremely simple to apply the tgsp. Put on the oneplus transparent silicone casing and use it as a short of guide to help you align the tgsp. And becuz its full adhesive, it will attach itself onto the screen once you remove the back film.
If there are any alignment errors, you can always just remove and reapply until you get the right fit. Last thing to do is to push out all the air bubbles with your fingernails. Next time you should attempt to apply the tgsp yourself instead of paying people outside for a next to nothing job.
kashix
Thx you for the advice! Will do and noted! For the 2 to 3 days, I can just use it normally right?
silverwing
Is this a must for orzly tgsp? I've been applying tgsp for all my phones, and I didnt put on the case.
