Gear S3 is announced.
hangyong
i suspect mine battery deteriorating i went down samsung service center in Plaza Singapura, thinking of just get the battery swap, to my suprise the damn battery replacement cost 190 dollar...
i left and never look back...
no one in town doing it so i guess it will be another spoilt tech in my drawer..
is it under warranty?
renfred89
last weekend I was using another adaptor which is QC2.0 ready. (have been using a normal charger all these while).
the wireless charging base is the original Samsung one.
the watch charged to about 94% and overheated, and after that, it kept discharging (or rather not charging).
That day, the battery dropped very quickly!
in the evening, used back the old setup to charge, and now all back to normal.
then likely it can be a hardware issue..
go service centre see what they say?
PPkiller
sound just like what i am experiencing.. except for the fact that i'm using a 6 port anker that only does 5v charging.
tskeng
got it too.. but everything seems to be working fine.
cleared the notification is it did not come back since.
I kept getting that despite clearing them. Like a few times a day.
There's an option to "block" that notification. But I was afraid the action might block all notifications from the same category but with different content.
:s22:
yhscsl
I just updated mine to tizen 3.0 and made a reset to watch. No such prob of such notification appearing at all. Monitoring the battery.
joesph
my non LTE after update after reset, sometimes gets too hot to charge fully
Sent from Samsung SM-G950F using GAGT
hangyong
ya yes, I did reset the gear after the update too, and come to think of it... its more likely that that cleared my error.
Fendi37
After updated my gear s3 LTE to tizen 3.0.0.1,certain original Watch face can't be used.Do u guys experience it?
Sent from Samsung SM-N950F using GAGT
xperiaz2
I faced the same problem despite resetting the watch more then 5 times. Went to service centre but no solution so far. They'll escalated the problem to headquarter as a couple of LTE users were also facing the same issue. Will post here when they contact me for a solution.
Fendi37
I see....thanks for your reply bro.I was just about to reset my gear again.Hope to hear the latest news from you.
evq
No wonder. I tot my watch spoilt. So many problems
yhscsl
Watchfaces not showing in Samsung Gear app amd watch itself. Many blanks.
Looking forward to hearing from u.
joesph
play store says gear app got update. I opened gear app in about app says no update
xperiaz2
Sure, will keep you guys updated on any development. Seems like quite a no of bros facing same problem. Those affected should make a call to Samsung
, so they'll take it seriously if many more are affected by the update.
