Is it a requirement to keep fire extinguisher in your car?
MonsteR-Z
Is it necessary given that fire stations is almost everywhere.
hachi
Got 1kg FE inside my car. Got it from Qoo10, less than $30. Save yourself or others in the event of emergency.
snipfer
MR DIY in Malaysia sells for RM10
Sent from Xiaomi MI MAX 2 using GAGT
MonsteR-Z
Where do u all normally store it? Safe to keep in the boot since flammable?
AL5509
Always a good to have item; thou it may not help totally if the flame got huge
But if your car caught fire and wait for fire engine to arrive, it is as good as seeing it burn to ash ba.
You will just feel helpless then.
Bought a small one and put inside my glove box.
Of course never hope to use it.
logitech123
i bought those cheap plastic end cap FE. the cap give way in hot parking lot..
chemical spray all under the seat. lol
tankgunner
Mentor
same same. got 1 for less than 50.
it leaked due to heat. lucky no damage to the interior of the car.
Archuke
Fire extinguisher put in car, make sure you park away from the sun.. cheap materials if under hot sun, what more the hot air no where to escape, sekali the pressure rise and burst in your car. Lagi jialat. Just a theory though
hachi
Those looked like a can of hair spray? Or those used in building with full metal construction?
AL5509
Those can type ba.
Like this:
Car Fire extinguisher (foam) for S$9 https://sg.carousell.com/p/151834825
Easy to fit and keep inside most glove box compartment.
