Is it necessary given that fire stations is almost everywhere.
Got 1kg FE inside my car. Got it from Qoo10, less than $30. Save yourself or others in the event of emergency.
Where do u all normally store it? Safe to keep in the boot since flammable?
Since when are fire extinguisher flammable? Lol
Fight fire with fire mah.
let it burn faster so that nth else more to burn is it?![]()
i bought those cheap plastic end cap FE. the cap give way in hot parking lot..
chemical spray all under the seat. lol
Fire extinguisher put in car, make sure you park away from the sun.. cheap materials if under hot sun, what more the hot air no where to escape, sekali the pressure rise and burst in your car. Lagi jialat. Just a theory though
not theory. tested and proven by me =[
Those looked like a can of hair spray? Or those used in building with full metal construction?MR DIY in Malaysia sells for RM10
Sent from Xiaomi MI MAX 2 using GAGT
Those can type ba.Those looked like a can of hair spray? Or those used in building with full metal construction?
