BSOD -> video_scheduler_internal_error
yangzhibin84
Recently built a PC but right after this happens. Below is the Error report. Please help :(
Crash Dump Analysis
Crash dumps are enabled on your computer.
Crash dump directories:
C:\Windows
C:\Windows\Minidump
On Wed 21/3/2018 5:30:48 PM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\032118-7343-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x175510)
Bugcheck code: 0x119 (0x2, 0xFFFFFFFFC000000D, 0xFFFFFA8CC9595960, 0xFFFFBF0A1F66C0D0)
Error: VIDEO_SCHEDULER_INTERNAL_ERROR
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that the video scheduler has detected a fatal violation.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\MEMORY.DMP
This was probably caused by the following module: ntkrnlmp.exe (nt!RtlDeleteHashTable+0x207)
Conclusion
2 crash dumps have been found and analyzed. No offending third party drivers have been found. Connsider using WhoCrashed Professional which offers more detailed analysis using symbol resolution. Also configuring your system to produce a full memory dump may help you.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
gld998
Check your gpu temp..
Sent from Old Man Pressing For Retirement using GAGT
yusoffb01
ntoskrnl problem is usually caused by faulty gpu. Try removing that
szeli
install older drivers if e latest ones have e same issue.
Rogue
Who build the PC for you? Go to device manager and see if there's any '?' devices or other devices...
Go to motherboard vendor website and download all the relevant drivers and firmware, install and update.
What other software did you install? List include your 3rd party stuff like anti-virus here...
Worse come to worse, bring it to a repair shop and let them do the troubleshooting for you... Or make one last attempt with a clean install of windows->install motherboard drivers->windows update->install gpu/sound drivers.
yangzhibin84
no third party software yet and it just bsod. Ok will try it out, thanks.
magix
I know the BSOD was pointing to GPU.
Since you already RMA the GPU and try running the system using on board graphic. Maybe can try RUN memory test and see if you have a faulty dimm.
yangzhibin84
ran memtest86 and passed twice
