Xiaomi Mi MIX 2S
swgj86
That's fast :s13:
Would be a hot seller here if it's priced similarly to the one in China, at RMB 99, especially for iPhone users :s12:
would it support 7.5W wireless charging for iPhone?
understand that only those explicitly stated "optimized for iPhone 7.5W wireless charging" will work .. if not will drop back to 5W.
https://www.macrumors.com/guide/iphone-x-fast-charging-speeds-compared/
For a separate post on wireless charging options, we've been investigating third-party wireless chargers, and it's looking like there may be a restriction put in place by Apple to limit 7.5W charging to approved manufacturers. As an example, on the Amazon page for this charger from Choetech, which says it is 7.5W, there is this message:
We get notice from Apple engineer that current IOS only support 5w qi wireless charging currently, 7.5w wireless charging is encrypted and never released to 3rd party manufacturer.
We've heard similar information from other manufacturers, but it's all very nebulous and not something Apple has clearly outlined at this point. For that reason, if you want confirmed 7.5W wireless charging, go with the Belkin, the Mophie, or another charger that specifically states that it's compatible with Apple's 7.5W charging.
pawn_king
Based on today's exchange rate,
$689
$752
$835
At this price point quite difficult.
If buying for camera, mate 10 can be had for 600+ with 2yr warranty with an equally good camera.
Else oneplus will probably have better performance/price when they launch SD845 model.
Wait for mi7? and hope for equally good camera at $500+ entry point
progene
P20 Pro price range most likely is like samsung S9+ range...
Sent from HUAWEI ALP-L29 using GAGT
amazingone
Yeah, the price of P20 Pro likely be over S$1k, while MIX 2S probably around S$700~S$800, can't compare directly..
casshern
Mix 2S running on SnapDragon 845 with 6gb ram, P20 on Kirin 970 with 4gb ram.
p20 have that stupid notch, Mix 2S is full bezel-less screen
p20 expendable storage, Mix 2s wireless charging
And price difference of both makes the choice even easier.
p20 $1k, mix 2S $700 (estimated conversion rate)
https://www.gizmochina.com/2018/03/28/xiaomi-mi-mix-2s-vs-huawei-p20-specs-comparison/
weeguy
Not a fan of notches but I thought Huawei mitigated it by giving users the option to obscure the notch. At least it appears less intrusive that way.
pawn_king
then again, a good 2 year local warranty is easily worth 20-30% more ;)
It's like insurance, ok if you don't need it, but u will curse why you didn't get it when **** happens lol.
That said ** touch wood ** nothing wrong with my 3 xiaomi phones that I use for over a year.
Hailgod
what can warranty do if anything happens? anything physical warranty already dont cover.
Sent from Xiaomi REDMI NOTE 4 using GAGT
Hailgod
huawei P20 Pro dethroned MiMix2S after half day...
The one that got dethroned is the s9+. So much for "Cameras Reimagined". huawei showed them the future
cscs3
Will skip P20 as Kirin 970 is not as good as SD845.
amazingone
Really? Though that kirin 970 is on par with it.
Kirin 970 is around the performance between Snapdragon 821 and 835 only, which is quite not at the flagship performance level as compared to other 2018 flagships such as Galaxy S9 series, Xperia XZ2 series, Mi MIX 2S etc.
