Xiaomi Mi MIX 2S
andyhtc
Suspended
According to this review, Kirin 970 is marginally better than Snapdragon 845 in benchmark tests:
Huawei’s Kirin 970 Outscores Qualcomm Snapdragon 845 In Test
https://www.androidheadlines.com/20...utscores-qualcomm-snapdragon-845-in-test.html
The power consumption for the chip itself should be similar since they are built on 10 nm FinFET.
The real world speed and power consumption depend on the manufacturer's optimisation of hardware and software.
brofeelgood
This could qualify as fake news. The report dates back to December, while the Snapdragon 845 was launched and measured only in March with the Sony XZ2, Galaxy S9/S9+ and Xiaomi Mix 2S.
The Antutu score of 213258 for the K970 is slightly better than the performance of the SD835 but nowhere near the 260-270k consistently registered by the XZ2, GS9 and Mix 2S.
Check out the latest test results (from the last few days):
https://www.gsmarena.com/check_out_huawei_p20_pro_benchmarks-news-30308.php
https://unite4buy.com/Huawei-P20-Pro-antutu/
As expected, the SD845 handily wipes the floor with the K970.
andyhtc
Suspended
Mix 2s is indeed very fast and much cheaper than other leading brands. If the camera video quality can be improved slightly, I would love to get one. I used to buy Xiaomi phones before I gave up on the camera.
cscs3
Kirin 970 is around the performance between Snapdragon 821 and 835 only, which is quite not at the flagship performance level as compared to other 2018 flagships such as Galaxy S9 series, Xperia XZ2 series, Mi MIX 2S etc.
That's right. Also, its power management is not as good as SD. Worse, quick charge is Huawei own standard and not QC3.0 compatible.
cscs3
Never believe in these benchmark test. This is just like test in PC. AMD result is always better then Intel. But in actual usage. Intel always win.
For power consumption, is not a matter of hardware only. Overall power management (software/firmware) in the chip play a important part.
The next consideration is price. P20/20+ is almost similar price to Samsung s9/s9+.
Nakedtoes
Yes the huawei p20+ camera looks promising but their processor not as stable as snapdragon.. some games or apps might have problem. at 40 % cost reduction the mix 2S is a much better buy..
Nakedtoes
Selfie camera still need to turn upside down??
:o
Better then most phone have that ugly notch up there right?? Xiaomi MIX series phone is really chio... and build quality is superb. else they wun be put inside design museums ard the world. I still using the beautiful MI MIX 1.. still a damed chio phone..
Hailgod
the essential phone did the notch quite well. too bad the company is a goner
Sent from Xiaomi REDMI NOTE 4 using GAGT
OutBreak
Have you used a Huawei phone before? I havent got any app crashing or unstable issue. Please stop the bs.
Nakedtoes
I used huawei before that is using snapdragon... their own processor is buggy go read review... some games might display artifacts etc..;)
OutBreak
You used a Huawei with Snapdragon SoC? So you have never used a Huawei phone with their own Kirin SoC. You already lost your credibility. Dont wink at me, it dont make you look smart.
Nakedtoes
So u use phone with kirin processor make u look smart? LOL great come i clap for u...:s13:
TheSnail
My only thought is wait a few weeks for Mix2S or a couple months for Mi7 with bit smaller display, which I prefer.
Problem is I need a phone definitely in the next couple of months and no news of Mi7 launch. Mix hits all the right numbers but screen size I think is big for one handed navigation.
Nakedtoes
6 inch still too big for yr hand?? u must be a petite lady..:o
