Xiaomi Mi A1 (Mi 5X) - Mi Dual Camera, Picture Perfect!
Alexz_Hong
Just found out that Xiaomi is selling the 4GB+32GB memory variant of Mi A1 at their Lazada official store now, at $259 :s12:
like bo hua leh. that time they selling 64gb at 269. haha.
absolut777
Once Android P announced, hopefully they port to Android One also, then Mi A2 may be worth considering.
tictactor
Just realise i hav the same problem w wireless@sgx......e phone will restart whenever i connect to wireless@sgx. Any solutions to this issue? I'm on Oreo (March patch). TIA
nah, i just decided to use 4G than risk some nonsense with this booting issue.
on a side note, received the march update (looks like they fixed the text)!
revhappy
I bought export set of Mi A1 4GB/64GB from a shop in little India for $222.
Sent from Xiaomi REDMI NOTE 4 using GAGT
tictactor
anyone has recs for a screen protector/tempered glass one? The one I've gotten on some random shop started to show off some weird oily patch underneath and despite removing it and cleaning the screen and the protector, it seems to be there
Audiology93
Is it "full coverage" type? If so, it is because there's no adhesive in the middle part hence causing the rainbow effect.
Sent from Xiaomi MI MIX 2 using GAGT
tictactor
nope, it's the full cover type, only seems to cover the screen (not bezel), front cam and capacitive buttons. Weird thing is, it only appeared in the top corner of the tempered glass, so the main display is unaffected except for a small ~2cmx0.5cm 'bubble' on the display
chromehead
these mi feels good man... went to shop to handle a few of the 5.5/6 inch
the reduced width makes for comfy handling like thumbing across the screen which i cannot do with my current 5.5 phone :s22:
Elnin0
Anyone realise the sim slot is thinner. i.e. I inserted malaysia sim card (thicker than singtel sim card).. now can't take out.
The ejection pin broken inside while I tried to press to eject the sim tray. :o
Intrinion
Senior Moderator
Senior Moderator
Eek, service centre
carboy00
Mi 6X may not come with a headphone jack.. :eek:
There's a leaked set of specifications stating that Mi 6x could come with Snapdragon 626. But judging from the TENAA listing, it does seem to be the case.
Sent from Xiaomi Redmi Note 4G using GAGT
greyice
I using malaysia sim in the secondary slot, no issue taking out.
lycanboy
Anyone faced this problem when using Google Map while driving? It kept playing the direction through phone's ear piece instead of the speaker.
Sent from 你妈妈喊你回家吃饭去 using GAGT
Apex
I reboot my mi A1 using Power key -> Select restart on the screen
-After that the phone never come back
- I plug in power for 2 hrs is still black screen and flashing white LED
so what now? Export set no warranty
bawawaw
Can't go recovery?
Apex
Can't go recovery?
I press VOL UP + POWER key nothing happen
so i dont know what happen.
The phone was working fine yesterday and this morning.. I just felt that too phone a little slow and kill apps didnt improve. SO just do a reboot using Software (press power key and select restart) and it nv come back :(
