Singtel Wifi Gigabit Router AC Plus
Ian
Just re-contract and was given this.
Currently using Asus RT-AC87U.
How good is it cause it's still in the box.
Ian
Seems that Singtel TV GO can't seems to detect my STB.
Maybe the Singtel Wifi Gigabit Router AC Plus is a must to install?
qyc_91
That Singtel modem is crappy i got 0.17 Mbps out of nowhere yesterday night. and Yes, based on the pic it seems like you have to connect your modem & crappy modem wirelessly then connect set top box with the crappy modem.
ZrE0_Cha0s
woah is that on wifi? like your devices is so far away from the router...
Pocoyoz
How you determine the transfer speed?
How to check the ip address of router without login to onr?
Sent from Pocoyo fan club using GAGT
pinkahlao
Go speedtest.net to check your speed.
To check ip address of router, run command prompt. Type the following,
Ipconfig/all
Then enter. Check the default gateway. That is your router ip address.
Lucky177
Used to serve me reasonably well in the past. But recent months, this router keeps on giving me intermittent auto no internet access via 5Ghz wifi despite just next to it / within line of sight.
Replaced router by technician previously also same. Finally gave up and switched to ASUS router. So far so good. Keep finger crossed. :s13: No more such issue. :)
Phen8210
This router is defective, intermittent issues. My relative is using it and i went over to help him troubleshoot, he had issue like yours too.. after tweaking here and there the speeds became normal but intermittently the issue returns.. i tried swap his network adapter and router, confirmed is the router issue.
chuppachop
Have the same issue too, the mobile phone Wi-Fi (5Ghz) frequently loses connection and reconnect awhile later.
Singtel - if you are reading this, please confirm and acknowledge the router is an issue and if another model will be rolling out soon, not AC Elite, AC Plus or AC 1900. Please advise.
Eidekos
I want to upgrade my router too coz this is lousy. keeps DC me on 5GHz.
what router is good and stable? and can just replace its connection direct to ONT? Thanks
chuppachop
I have to use back my Old Aztech FG7003GRV (AC) , then Dun have disconnection issue, but the speed is slower, and it's a SU-MIMO also. Sianz.
Eidekos
is the Asus RT-AC1200G+ router an upgrade to the ac plus from singtel? or need ac 88U? or 68U? thanks
dryteletubby
In terms of WiFi speed , features or stability?
Most Asus routers should have the OpenVPN server functionality, file server + download server, time machine,traffic analyzer etc.
WiFi speed depends more on your device and interference +obsticals around your house.
Stability will be questionable for most consumer grade routers. Many of them needs to be restarted at least once a month or earlier and some of them can overheat if placed in a confined space or worked too hard etc.
If you want stability go for devices from mikrotik & ubiquiti. I use a ubiquiti AP that worked flawlessly for over a year since the day I bought it.
Eidekos
speed and stability. currently inna 2br condo. ac+ is in the living room. subscribed to singtel 1Gb plan
so if there is more room to improve, looking at ea7500? or really need a triband to awe the difference?
dryteletubby
There is no point having a tri band router unless you have 100+ devices all in the same room as the router/AP
For Singtel unless you have an ONT you will be forced to use your router in AP mode only. Also your router will have to support the Singtel preset or manually tag vlans.
If you want you can put an AP in each room for 5ghz coverage for your whole house.
Pocoyoz
Wifi Frequently Disconnect and reconnect
kero89
How about a totally different approach and try out mesh system? Like Singtel airties Wi-Fi mesh for $10/mth for a pair, one of the more affordable option to go mesh
chuppachop
I wonder if this is considered a service lapse as the provided routers are not working in the first place. Can IMDA take action on Singtel for this? Shall check out the IMDA website shortly.
Mach3.2
Seem like a widespread issue eh, my neighbour is also pulling his hair out due to the intermittent connectivity issues with this RG... :s22:
No issues when connected directly to the RG with ethernet cable.
