Seems that Singtel TV GO can't seems to detect my STB.
Maybe the Singtel Wifi Gigabit Router AC Plus is a must to install?
Just re-contract and was given this.
Currently using Asus RT-AC87U.
How good is it cause it's still in the box.
That Singtel modem is crappy i got 0.17 Mbps out of nowhere yesterday night. and Yes, based on the pic it seems like you have to connect your modem & crappy modem wirelessly then connect set top box with the crappy modem.
How you determine the transfer speed?
How to check the ip address of router without login to onr?
Sent from Pocoyo fan club using GAGT
No more such issue. ![]()
is the Asus RT-AC1200G+ router an upgrade to the ac plus from singtel? or need ac 88U? or 68U? thanks
In terms of WiFi speed , features or stability?
Most Asus routers should have the OpenVPN server functionality, file server + download server, time machine,traffic analyzer etc.
WiFi speed depends more on your device and interference +obsticals around your house.
Stability will be questionable for most consumer grade routers. Many of them needs to be restarted at least once a month or earlier and some of them can overheat if placed in a confined space or worked too hard etc.
If you want stability go for devices from mikrotik & ubiquiti. I use a ubiquiti AP that worked flawlessly for over a year since the day I bought it.
speed and stability. currently inna 2br condo. ac+ is in the living room. subscribed to singtel 1Gb plan
so if there is more room to improve, looking at ea7500? or really need a triband to awe the difference?
I wonder if this is considered a service lapse as the provided routers are not working in the first place. Can IMDA take action on Singtel for this? Shall check out the IMDA website shortly.Wifi Frequently Disconnect and reconnect
