Actually SH is not too bad, definitely better than VQ. That's my own experience with VQ for 1 year and 10 months. At least SH rarely get disconnected for no Fcking reason.
Hi
possible to share you EA7500 connectivity setting in pm?
i just recontract with SH 1Gbps swapping ouy my dir878 and am getting crappy connection.
did the quick set up and played around with the settings... restarted every thing and still the same..
only getting about 1/3 of my subscribed...
wifi signal strength wise its alot worst compared to the 878
if all else fails i'll just swap back to the 878
many thanks in advance
Hi
Check your LAN connection speed, what speed are you getting ?
Example![]()
If you can, put the router higher, make sure the 2 antennas (left most & right most) are at an angel and not straight up.
Are you testing in WiFi? If so change the 5ghz band to vht80 and choose a less congested channel for 2.4ghz
1.1.1.1 is Cloudflare DNSwhat DNS are these? i've tried google, open and default but not these
lan speed not very impressive as well... about 1/2 or slightly higher but no where near 1Gbps...
did i forget to mention the pos is the same with my DIR878 which was giving much better results
9.9.9.9 is Quad9 DNS
Google and you find out more information about them
If you lan connection status cannot get 1Gbps, high chance cable issue.
Sent from Samsung GT-N5120 using GAGT
Funny, i get 100% coverage with this router
Hi
Anyone can use this EA7500v2 with SingTel Fibre w/ Mio TV?
Tested change the VLAN to SingTel, but super slow.
Cloudflare seems to slow down my web browsing.
Changing back to OpenDNS FamilyShield as Pri DNS.
Browsing seems like back to a breeze............haha
Finally got my Linksys EA7500 today.
Speed not bad compared to Dlink DIR-868L
Can't believe 3rd SH contract.
How you get that speed? I have 1 gbps plan but my d/l 430mbps up 542mbps only. I tried to call starhub and the person on the phone told me to test and connect the cable from ONT port 1 to my laptop. It did shows 900+ mbps but it makes no sense telling me by connecting ONT>LAPTOP i will get full speed while connecting ONT>ROUTER>LAPTOP i will get less?
