Pi-Hole kit
-Grift-
dryteletubby
same could be said for all the raspberry pi kits like pi top, canakit etc. mostly sold to people who want to be handheld throughout the setup. not exactly a bad thing.:s13:
alvinym
i wonder if such devices can be plugged directly to the ONT since the ONT i have has a usb port. But how do i set the DNS ... hmmm ...
dryteletubby
You will have to plug a network cable from your router to the raspberry pi. The pi can be powered from the usb port of your router or ONT.
DNS can be set in your router admin page or on your device itself
uncle_josh
Those who are too lazy to setup pihole yourself can use these PUBLIC-PIHOLE
Simply 2 of the DNS (1x Primary and 1x Secondary) into your router will do
squarepipe
If you are technical enough to know about pi-hole, why not go all the way and learn how to set it up? No reason to be in this middle ground.
Farish
I'm running 2 x Pi-holes and unbound on my home network and there is no down-sides to it. Wont be going back to the ISP's DNS or any other for that matter.
Farish
