Official OnePlus 6
kuma-mon
Cheap and Good = Slow
Cheap and Fast = Bad
Good and Fast = Expensive
Pick one!
Lolol i understand.
Anyway i tried checking out op6 from hk, what address do i put for borderlinx?? Postal code shows as 'Cheung Sha Wan" but they require a legit digit postal code. And what region do i put? None shows the same as my address
mudxblood
Lolol i understand.
Put Sham Shui Po
Sent from Google PIXEL 2 XL using GAGT
micshang
Lolol i understand.
Me facing the same thing.. Don't know what to put for my hotel address im Mongkok. Don't know what region and postal code to put :s11:
kuma-mon
Mine is 1600-XXXX. This is your Borderlinx account address I think.
Which model you planning to order?
Im just gonna order 64gb.
Kinda weird because hong kong dont have postal code but i have to key in some digit postal code. Just wanna confirm if ur postal code is the 8 digits located at the top of the address?? 1600-XXXX Borderlinx C/O XXX
Just wanna make sure i insert the correct address haha
CrispyPeddler
this is kinda crazy pricing
in carousell ppl are selling p20 pro at $850
one plus 6 around $880
if compared, p20 pro seems to be better than op6 (in term of features)
damn, now im hesitating which 1 to get:s22::s22:
Mclairs83
T version doesn't have a CPU upgrade. 5 and 5t was sd835. Its usually incremental upgrade in the 5t case was screen only.
Look at it this way, 6 and 6t price will probably be the same.
The point of paying same price for 6 is to use the latest and greatest processor for 6 mths, after that when 6t comes out sd845 will feel a little dated already as Huawei will come out with new kirin processor etc
If you are an OnePlus user, u won't look at Huawei Kirin.. please :s22:
mudxblood
Yes, postal code put cheungshawan. State put Sham Shui Po
Audiology93
845 > 970. No need to hesitate. Go for OP6.
Sent from HUAWEI MATE 10 using GAGT
kuma-mon
Huh? Im confused lol. So i put cheungshawan or a digit postal code? It only allows me to put digit postal code i think. Then what u put for address field??
CrispyPeddler
OP6 - S$880.00
- Android purist + good customisation
- Fluid OS
- 845
- 2160 60 fps
- fast charging
P20pro - S$850.00
- One of the best camera (triple lense
- IP67
- 4000mah
- fast charging
- infrared (remote control)
- usb 3.1
not sure if i just want fast cpu :s22::s22:...
why op6 so expensive? i thought its suppose to be cheap and good?
KeYoKe
OP6 - S$880.00
- Fluid OS
- 845
- 2160 60 fps
- fast charging
P20pro - S$850.00
- IP67
- 4000mah
- fast charging
- usb 3.1
get from qoo10 131express? at least is 819 for 8gb 128gb, not sure if makes it more worth for u to hoot Op6 hahaha
Skyy
OP6 - S$880.00
- Fluid OS
- 845
- 2160 60 fps
- fast charging
P20pro - S$850.00
- IP67
- 4000mah
- fast charging
- usb 3.1
You forgot Huawei got warranty, 2 years I think
Audiology93
OP6 - S$880.00
- Fluid OS
- 845
- 2160 60 fps
- fast charging
P20pro - S$850.00
- IP67
- 4000mah
- fast charging
- usb 3.1
I find OxygenOS better than EMUI. Recently started to play PUBG mobile so performance is very impt to me. I could see some frame drop on my Mate 10(970) but when I played it on my Mi Mix 2(835), I didn't encounter as many frame drop.
deathst
OP6 - S$880.00
- Fluid OS
- 845
- 2160 60 fps
- fast charging
P20pro - S$850.00
- IP67
- 4000mah
- fast charging
- usb 3.1
They have never been cheap since OP5.
