Just Me
- Jan 1, 2000
The correct way of chemical overhaul is to dismantle down the whole unit and clean it parts by parts and also to apply lubricant on the bearings. If the fan motor is rusty then next time general service cannot dismantle the blower le cause can't take out.
As for gas leakage might due to the joint between the copper pipe is not tight enough. Or unit coil evaporator is too rusty on the side
I still strongly recommend to dismantle down follow the correct way of washing..
That's why $200 for 3 units. Others they will charge higher if dismantling is done
