The Hair Thread - Part 5
Iniesta08
I am looking for an alternative product to Morris motley to use on a daily basis as MM is a litte too expensive for daily use.
Is Arcadian Clay Pomade good?
Any recommendation?
Thanks in advance!
Otterside
hi guys, looking for a good salon price range 30-40 bucks around Far east plaza.. any recommendations? thanks
blackvice
Is Arcadian Clay Pomade be good?
Any recommendation?
Thanks in advance!
Vifa moulding clay. 130ml for 18.90 from jun hong bro. Best bang for bucks.
HyperBaka
hey guys, been using joico erratic clay and gatsby super hard hairspray for many years alrdy and now looking for a change.
any recommendation for hairspray?
would want a matte and non shine finish with strong holding power!
leejhong
One of the many options is Powerpoint Hairspray :)
It's good to switch over from Gatsby because gatsby hairspray gives a really unnatural finish and it produces lotsa white flakes
leejhong
I may like to reccomend you vifa moulding clay which you can get from jun hong bro.For that price and package, it adds a slight sheen, scent and also ease to wash, if you're looking to that. By villian products are not easy to wash off imho.
Thanks for the shout-out for vifa clay bro! Glad that you like it too :)
To add on - Vifa clay is definitely one of the best products in terms of hold and washability that I have ever used! Very well-balanced across these 2 areas which is not commonly seen.
voltshin
May i ask where to get pointpoint hairspray?
Dagionax
Hi there, couldnt find your contact on my end. Nonetheless, for your info, prices are fixed. Hence, all lower offers made via carousell will be declined so as to be fair to all consumers. And yes, bro nich is right! Tigi bedhead hairspray is good too. :)
Not sure what you mean by prices are fixed because I offered exactly the price stated. Thanks for revealing yourself, made me wait for a full hour at the indicated meet up time and not showing up. I guess I know who NOT to buy from now
leejhong
Hi, sorry to hear about your experience but i am afraid you might got the wrong guy. We dont arrange meetups without appearing. :)
gascon7
Hidden gem
Not sure if anyone tried but Check out Dominate in most supermarkets. NZ brand.
They dont use Parabens. I got the Out of bed and its almost what I was looking for medium to long hair to be able to use one product and finger comb loosely into place. No hairdryer or hairspray. Try it out think some maybe pleasantly surprised. If you have thinner hair try some of their other higher hold ones.
xRenol
Darn, I tried to buy from that guy last time and he was no-show, refused to accept the offer as well so I couldn’t leave feedback. Guess I’ll try tigi hard head next, thanks!
Are you referring to ratxshopworldwide on carousell or bro leejhong?
Deyston9
Hi guys, I’m looking for wax that give wet look. As I want to try those Korean middle parting hairstyle. Hope to have you guys advice :)
Trans-Am
Which product to use for undercut hairstyle?
Sent from :bandit:
Stay low Move fast !
Shoot first Die last !
One shot One kill !
No luck Pure skill !!
:s17: using GAGT
sansanjikikut
Geddit now fellas! https://morrismotley.com
Free worldwide tracked shipping as well
Greenworm
Anyone went for a haircut at Splice Barbershop over at Suntec?
It’s been a long time since i had a good haircut liao and my hair is quite messy and uneven now. That time i had a haircut over at fareast few years ago was $30+ but that saw walked past Splice which looked damn Atas, saw the price which was $50 for a haircut. :eek:
ecan07
Hi bros,
I'm gg to Sydney for a trip (like practically on the plane now).
Any tips where can I go get MM TSB there? Is it cheaper there by any chance?
sansanjikikut
Its cheaper if you buy online actually.
Chrome cheap because old stocks, products advertised with shine not easy to sell here in SG. You can check the brand name on the container of chrome, if its not all caps its old stock.
The "newest" version is all caps branding label on BOTH the jar and the white box.
