Xiaomi Redmi 6 series
lohsenglte
Redmi 6 front panel revealed
Walao this got to be one of the worse Redmi smartphone design sia
mun
design is okay lar... similar to mi max series. let's wait and see the spec and features bah 😐
amazingone
Hopefully redmi note 6 not in the list 😛
If not a lot of ppl will be in rage 😂
Tomorrow will only have Redmi 6A, Redmi 6 and Redmi 6 Pro. :o
Specs:
Redmi 6A:
- MTK MT6761 2.0GHz quad-core, 14nm
Redmi 6:
- MTK MT6762 (Helio P22) 2.0GHz quad+1.5GHz quad octa-core, 12nm
Redmi 6 Pro:
- Snapdragon 625 2.0GHz octa-core
carboy00
Specs:
Redmi 6A:
Redmi 6:
Redmi 6 Pro:
Thought they were done with MediaTek chips for good. I guess not.
Sent from LG G3 using GAGT
ZrE0_Cha0s
It's reported by various tech websites that the model number that was registered as Mi A2 Lite in our IMDA database is similar to the model number of the Redmi 6 Pro registered in China's TENAA database. :s12:
https://www.gizmochina.com/2018/06/03/mi-a2-lite-passes-through-singapores-communications-authority/
Tbh did expected that mi A2 lite is using 636 given that 660 was using in mi A2.
That also means that if one have mi A1 b4 getting a mi A2 lite is just an incremental upgrade :s22:
carboy00
If priced right, I think Mi A2 Lite will be a good deal, I am okay with Snapdragon 625 on a lower priced phone rather than a MediaTek chip to be honest.
amazingone
Introducing the Redmi 6
- 5.45" 18:9 fullscreen HD+ display
- Size similar to traditional 5" 16:9 phone
Comes with a curved body
