lohsenglte
- Dec 13, 2013
Redmi 6 front panel revealed
Walao this got to be one of the worse Redmi smartphone design sia
Tomorrow will only have Redmi 6A, Redmi 6 and Redmi 6 Pro.Hopefully redmi note 6 not in the list
If not a lot of ppl will be in rage![]()
I feel the Redmi 5 looks better, with smaller bezels than the Redmi 6 and also have the Selfie-light flashWalao this got to be one of the worse Redmi smartphone design sia
Specs:
Redmi 6A:
- MTK MT6761 2.0GHz quad-core, 14nm
Redmi 6:
- MTK MT6762 (Helio P22) 2.0GHz quad+1.5GHz quad octa-core, 12nm
Redmi 6 Pro:
- Snapdragon 625 2.0GHz octa-core
6A will be replacing the 5A, definitely priced lower than the S2.Definitely agrees with u in this matter. So is the 6A gonna be like S2?
The Redmi 6 Pro may be named as the Mi A2 Lite globally.Maybe its for china. India will still be using SD 625 XD
The Redmi 6 Pro may be named as the Mi A2 Lite globally.![]()
It's reported by various tech websites that the model number that was registered as Mi A2 Lite in our IMDA database is similar to the model number of the Redmi 6 Pro registered in China's TENAA database.erm......![]()
Tbh did expected that mi A2 lite is using 636 given that 660 was using in mi A2.It's reported by various tech websites that the model number that was registered as Mi A2 Lite in our IMDA database is similar to the model number of the Redmi 6 Pro registered in China's TENAA database.
https://www.gizmochina.com/2018/06/03/mi-a2-lite-passes-through-singapores-communications-authority/
A backward in design, when the Redmi 4 and 5 series(except 4A and 5A) all feature downward-facing speaker..Speaker placement back to rear of phone.
Sent from Xiaomi Mi 5 using GAGT
I heard mediatek not power efficientIf priced right, I think Mi A2 Lite will be a good deal, I am okay with Snapdragon 625 on a lower priced phone rather than a MediaTek chip to be honest.
Sent from LG G3 using GAGT
only launch 1 phone ? price ? spec ?
