GloveK8
- Jun 20, 2004
Hi guys
its me again, basically the contractor is very nice he came down and replace a few parts but he did not charge me as it did not solve the problem. He even get mitsubishi down and change according to what mitsubishi had advised. Now 2 aircons are working but not as cold, and 1 aircon is not working. basically mitsubishi have advised that the electronic valve is faulty. Before that, the contractor had already changed the thermistor pcb and electronic valve already.
I think last resort is to change the whole condensor and compressor, can i know what is the usual price to change the condensor and compressor? my whole family is really damn fed up with the aircon under this hot weather. Appreciate if anyone have had such experience.
My unit is almost 4 years old. wondering if it is common for mitsubishi starmex aircon?
Thank you!
Thank you!
Hey guys sorry for no reply. I engaged another company. Initially they said thermistor and electronic valve spoil. Replace alr still not working. Then say pcb spoil. Replace pcb also not working. Now lagi jialat. All 3 units are not cold now. The contractor is saying they will check with mitsubhishi. My aircon are only installed since 2014. I am seriously considering going to CASE now for this issue. Anyone have had similar kind of experience. I would deeply appreciate if you can advise on how should i proceed with this situation. Thank you!
