Digital TV (DVB T2) Consolidated thread IV
lanzhu60
Hi ,if I have a Nvidia TV box ,jus need an antenna only right ? Bought an antenna online but seems the connector doesn't fit the TV directly . Any advise ?
amazingone
Nvidia TV Box is not a Digital TV tuner set top box..
It's just an Android box.
albertlee
Thanks for reply . In tis case ,if my TV is digital ready ,just need an antenna to connect to TV and it can co-exist with my Nvidia box ?
Yup as long as there is sufficient HMDI ports on the TV to hook up all the different boxes.
zzxxzzxx
If your TV is DVB-T2 ready, then you just need an Antenna.
Your Nvidia Box is only thru HDMI, will not affect your Normal TV viewing.
cokecheers
Get Free setup box + Antenna or redeem $100
Hi have 3 flat screen tv at home and all are not digital TV. Does it mean I need to have 3 set of digital setup box + Antenna in order to watch digital tv for all 3 TV?
I am entitled to the Free starter kit by IMDA, is it more worth it to get the Free setup box + Antenna or redeem $100?
albertlee
Yup, STB + antenna for all TVs
And no, you can't redeem DTV kit as cash, you either opt for approved STB or use it to offset purchase of TV or antenna.
cokecheers
Is the approved STB a better deal or use it to offset the purchase of a STB and antenna?
albertlee
Which is a better choice? Any recommendation? Thanks.
I'm more gear toward Draco since they have a head start when DTV was first introduced here, meaning more stable firmware. But the copy-protection feature is a turn-off, it seem like all approved STB have this! :(
yes1705
Found the answer.
Courts selling the Draco HDT2-7700 bundle with Funke DSC250 active antenna for $100. But look like it has the same copy-protection feature as the NMS. :(
Still need confirmation on the copy-protection (HDCP) part.
https://www.courts.com.sg/draco-hdt...ital-tv-receiver-bundle-with-antenna-ip138947
Found the same $100 offer on Courts online store. Can I buy online and pay COD with Digital TV voucher to delivery guy? :D
tk
can i use the $100 voucher to redeem 2-3 antennas? i dun really need a dvbt2 receiver box..
Medicated Oil
High Honorary Member
Yes.
It is stated clearly in the letter antenna(s).
Dun be hoodwinked by the store assistants who say NO to you.
