Shion
Senior Mentor
- Oct 24, 2008
Can get some indo analog channels but some too fuzzy can’t really see. do they haf digital channels yet? Wat channels/freq?
I don't think so
R they in HD or SD?Indon channel 48 n 52 for digital channels.
Antenna: High gain antenna with amplifier 30dbi 5m usb and NMS ANT3-3AB
TV: Sony 47W804A with DTB2
Important note: As long as has usb power boost+putting at window can receive the signal from malaysia. Once left window all signal lost except singapore local channels.
Better use manual scan. Set 2 required freq/channel, use signal strength n quality display 2 find best spot den scan. Need 2 move antenna around 2 find best spot n might need 2 hang antenna out of window 2 get it. Previously I use auto scan never get anything.Hi, Thanks for your post. Me at Yishun Ring Road too. I am using the same antenna NewMedia Solutions ANT3-3AB too. May i know do you use the TV auto tuning or manual tuning to get the Malaysia channels?
With you own antenna?Malaysian channel only, AMK area, Horizon Green
Hi all, just received my mailer from IMDA for DTV for a rather old tv. Should I opt for the free set-top box + antenna package with installation by IMDA or present the letter to get $100 off dtv equipment? Would like to try to get channels from Malaysia. If so, what's recommended? Thanks in advance!
Get the installation package, at least they will help you receive SG DTV channels first. Then u can play around with the manual tuning to try receive Malaysia ch 47.
This DTV ch47 is only available for people leaving up north as Batam is also transmitting on their analog SCTV on ch47
Can ? I see can only scan for region Singapore.
Connected my starter kit to the MATV antenna - working
Now trying to scan Malaysia channels. Do I need to specify which channel no. before I scan ?
Can post picture of MATV antenna?
For me, I can receive all Malaysian digital tv channels, sometimes when weather isn't good or when F16 fly past, the reception will go haywire. Otherwise still watchable.
My area is in Jurong. Very low floor and blocked my trees and buildings.
What type of antenna you use ?
